Can C1FlexGrid support Placeholder feature?
Posted by: freedom93123 on 13 January 2022, 5:21 pm EST
    Posted 13 January 2022, 5:21 pm EST - Updated 3 October 2022, 10:43 pm EST
    Hi there,
    I would like to know if there is any property to set placeholder in C1FlexGrid like below?
    If no, then it means I shall write my own placeholder source code by using BeforeEdit event, AfterEdit event and change cell style to grey font etc, in order to achieve ‘Placeholder’ effect.
  • Posted 14 January 2022, 5:10 am EST
    There is no direct property for the placeholder in C1FlexGrid. As a workaround, you can use the OwnerDrawCell event to manually draw the placeholder text on the cells of the required columns when they are empty. Kindly refer to the attached sample showing the same.
    Kartik Dua
    Placeholder_C1FlexGrid.zip
  • Posted 14 January 2022, 6:17 am EST
    Thanks Kartik Dua,
    You’ve made my day.
