Can not create InputDatePicker
Posted by: moridi on 14 June 2019, 3:17 pm EST
  • Posted 14 June 2019, 3:17 pm EST
    My windows calendar is Persian calendar and if i want to add InputDatePicker in InputPlanel show me the error and if i want ti add via code show this error
    System.ArgumentOutOfRangeException: ‘Specified time is not supported in this calendar. It should be between 03/22/0622 00:00:00 (Gregorian date) and 12/31/9999 23:59:59 (Gregorian date), inclusive.
    Parameter name: time’
    how can i solved this problem?
                var c = new InputDatePicker
                    Name = "InputDate1"
  • Posted 14 June 2019, 3:22 pm EST
    " at System.Globalization.PersianCalendar.CheckTicksRange(Int64 ticks)
    at System.Globalization.PersianCalendar.GetDatePart(Int64 ticks, Int32 part)
    at System.Globalization.PersianCalendar.GetYear(DateTime time)
    at C1.Win.C1InputPanel.XInputDatePicker.DateInfo.SetDate(DateTime date)
    at C1.Win.C1InputPanel.XInputDatePicker.DateInfo…ctor()
    at C1.Win.C1InputPanel.XInputDatePicker…ctor(InputDatePicker inputDatePicker)
    at C1.Win.C1InputPanel.InputDatePicker.CreateElement()
    at C1.Win.C1InputPanel.InputComponent…ctor()
    at C1.Win.C1InputPanel.InputDatePicker…ctor()
    at Jafrnas.IForm.AddDate(InputItem item, Int32 idx) in D:\Nastouh Program\Abjad\Jafrnas\Jafrnas\IForm.cs:line 81
    at Jafrnas.IForm.IForm_Load(Object sender, EventArgs e) in D:\Nastouh Program\Abjad\Jafrnas\Jafrnas\IForm.cs:line 67
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.SetVisibleCore(Boolean value)"
  • Posted 16 June 2019, 3:20 pm EST
    I check with other calendar like hijri.
    only work with Gregorian
  • Posted 17 June 2019, 2:26 am EST
    I can observe this issue. I’ve asked the developers to look into this [Internal Tracking ID: 384920].
    I’ll update this thread as soon as we receive any information from them.
    Jitender
  • Posted 21 June 2019, 11:22 am EST
    I solved the problem with InputControlHost and C1DateEdit but you can go on to solved the problem.
  • Posted 24 June 2019, 12:04 am EST
    Thanks for sharing your workaround for the issue. I’m sure it will be helpful for anyone else who might face this issue while the bug is being fixed.
    Jitender
  • Posted 11 September 2019, 2:05 am EST
    This issue has been fixed in the latest hotfix build (4.*.20192.382).
    You can download the fixed builds from this link:
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms-452_4.5.20192.382.zip
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.4_4.0.20192.382.zip
    Jitender
