Change Sort Icons in C1TrueDBGrid
Posted by: jmnieves on 8 April 2022, 3:58 am EST
    Posted 8 April 2022, 3:58 am EST
    Hi
    I like to change default sort icons by another customs icons in c1truedbgrid. I cant see in theme editor.
  • Posted 11 April 2022, 2:56 am EST
    Hi, I need to make better the UI, without change it , its imposible to view clear the buttons of sortings
  • Posted 11 April 2022, 5:34 am EST
    We apologize for the delay in response. Changing the sort icons of the C1TrueDBGrid is not directly possible. As a workaround, you can set the AllowSort property of the C1TrueDBGrid to false and handle the HeadClick event to manually sort the C1TrueDbGrid. Then, you can use the C1DisplayColumn.HeadingStyle.ForegroundImage property to show your custom sort icon in the column header. Kindly refer to the attached sample showing the above approach.
    Sample_CustomSortIcon.zip
  • Posted 11 April 2022, 6:41 am EST
    Hi
    It’s not a workaround because its disable the event after_sort … I dont understand the reason that we can not change this “BASIC ELEMENT”, the arrows are so bads, unclears, in transparent color… We pay 1K for licence for this?
  • Posted 12 April 2022, 1:06 am EST
    We understand your concerns. We have escalated the issue to the development team to get their insights on it. We will let you know as soon as we have an update. We apologize for the inconvenience caused.
    Kind Regards,
    [Internal Tracking ID: C1WIN-27240]
  • Posted 25 April 2022, 7:14 am EST
    Any notice about this?
  • Posted 25 April 2022, 7:25 am EST
    We are getting in touch with the development team to get an update on the issue. We will let you know as soon as we get an update.
    Kind Regards,
  • Posted 26 April 2022, 2:06 am EST
    We are sorry to inform you that currently there is no API available to change the sort glyphs of the C1TrueDbGrid. We have sent an enhancement request for the same to the development team. We will let you know as soon as we have an update.
    Kind Regards,
    [Internal Tracking ID: C1WIN-27273]
  • Posted 2 December 2022, 9:30 am EST
    We are glad to let you know that this enhancement has been incorporated in the latest 2022v3 (584) release. Now you can customize the sort glyphs using the C1TrueDBGrid Glyphs property.
    The link for the latest NuGet package is given below. The 2022v3 release will be available for download from the C1 Control Panel in a few days.
    (https://www.nuget.org/packages/C1.Win.C1TrueDBGrid/4.5.20223.584)
