Chartfield scaling
Posted by: saidnai on 29 April 2022, 5:32 am EST
  • Posted 29 April 2022, 5:32 am EST - Updated 3 October 2022, 10:30 pm EST
    I am using a function to create Chart. It works fine. But i could not set scaling for the AxisY. I need to ovoid the decimal as shown in the attached picture. Is there a possibility to get only full numbers (1,2,3,4,5, e.t.c).
    I use the following function:
    Private Function CreateChart1() As ChartField
    Try
    Dim chart = CreateChartField(“Chart1”, “TmpStatistikEK1”)
    chart.Top = 4100
    chart.Left = 400
    chart.Height = 3500
    chart.Width = 4800
    chart.Border.Style = BorderStyle.FixedSingle 'DashStyle.Solid
    'chart.Header.Text = “Reklamation 1”
    chart.ChartArea2D.Inverted = False
    chart.ChartArea2D.AxisX.OnTop = True
    chart.ChartArea2D.AxisX.AnnoRotation = 50
    chart.ChartArea2D.AxisX.Font.Bold = True
    chart.ChartArea2D.AxisX.Visible = True
            chart.ChartArea2D.AxisY.GridMajor.Visible = True
            chart.ChartArea2D.AxisY.Font.Bold = True
            chart.ChartArea2D.AxisY.AutoMax = False
            chart.ChartArea2D.AxisY.AutoMin = False
            chart.ChartArea2D.AxisY.Min = 1 'Scaling Min
            chart.ChartArea2D.AxisY.Max = 1 'Scaling Max
            'TickMajor / TickMinor
            'chart.ChartArea2D.AxisY.TickMajor = 1
            'chart.ChartArea2D.AxisY.TickMinor = 1
            'AutoMin / AutoMax
            'chart.ChartArea2D.AxisY.AutoMin = 1
            'chart.ChartArea2D.AxisY.AutoMax = 1
            'AutoMajor / AutoMinor
            'chart.ChartArea2D.AxisY.AutoMajor = 1
            'chart.ChartArea2D.AxisY.AutoMinor = 1
            'UnitMajor / UnitMinor
            'chart.ChartArea2D.AxisY.UnitMajor = 5
            'chart.ChartArea2D.AxisY.UnitMinor = 5
            'GridMajor / GridMinor
            'chart.ChartArea2D.AxisY.GridMinor.MiterLimit = 10
            'chart.ChartArea2D.AxisY.GridMajor.MiterLimit = 20
            'chart.ChartArea2D.AxisY.GridMinor.Visible = False
            'AutoOrigin
            'chart.ChartArea2D.AxisY.AutoOrigin = 1
            'Origin
            'chart.ChartArea2D.AxisY.Origin = 1
            'Breite der Strich = TickFactorMajor / TickFactorMinor =
            'chart.ChartArea2D.AxisY.TickFactorMajor = 10
            'chart.ChartArea2D.AxisY.TickFactorMinor = 1
            'TickGauge
            'chart.ChartArea2D.AxisY.TickGauge = 1
            chart.Legend.Visible = False                                 'Die Legende zeigen oder nicht
            'chart.Legend.Location =
            Dim group = chart.ChartGroups2D.Group0
            group.ChartType = C1.Win.FlexReport.Chart.Chart2DType.Bar   'Chart2DType.Bar
            Dim data = group.ChartData
            data.IsForEachRecord = True                                 ' show value of each record in data source
            data.CategoryGroups.AddNewGroup("=TxTWert")      ' group by FullName
            data.ColorMode = ChartColorMode.ColorByCategory             'Für Unterschiedliche Fareben
            Dim seriesTemplate = data.SeriesValues.AddNewSeries()
            seriesTemplate.DataValues.AddNewValue("=AnzLieferungen")    ' show count in AxisY
            seriesTemplate.LegendEntry = True
            'Show the values
            seriesTemplate.DataLabel.Visible = True
            seriesTemplate.DataLabel.Text = "{#YVAL}"
            'Values display location and fonts
            seriesTemplate.DataLabel.Compass = ChartLabelCompass.North 'i.e. On top of bar
            seriesTemplate.DataLabel.Style.Font.Bold = True
            Return chart
        Catch ex As Exception
            MsgBox("Error 'CreateChart1' :" & vbCrLf & ex.ToString, MsgBoxStyle.Critical)
        End Try
    End Function
    Said
  • Posted 2 May 2022, 4:40 am EST
    Hi Said,
    Thanks for the code snippet and snapshot.
    You need to set AxisY.UnitMajor=1 to achieve your requirement as(see code snippet)
    chart.ChartArea2D.AxisY.AutoMajor = False
    chart.ChartArea2D.AxisY.UnitMajor = 1
    Please refer the attached sample for the same: FlexChartScale.zip
    Nitin
