Posted 20 December 2022, 1:21 am EST
Please let me know how we can convert xls and xlsx into data table in vb.net
Posted by: skm.mas on 20 December 2022, 1:21 am EST
Posted 20 December 2022, 2:36 am EST
As of now, there is no direct way to convert excel to a data table but you can use the Documents for Excel API to get the values from excel cells to data table by using the code snippet given below:
https://www.grapecity.com/documents-api-excel/docs/online/overview.html
Dim workbook As Workbook = New Workbook() workbook.Open("demo.xlsx") Dim dt As DataTable = New DataTable() Dim worksheet As IWorksheet = workbook.Worksheets(0) For i As Integer = 0 To worksheet.UsedRange.ColumnCount - 1 dt.Columns.Add(worksheet.UsedRange.Cells(0, i).Value.ToString(), GetType(Object)) Next For i As Integer = 1 To worksheet.UsedRange.RowCount - 1 Dim dr As DataRow = dt.NewRow() For j As Integer = 0 To worksheet.UsedRange.ColumnCount - 1 dr(j) = worksheet.UsedRange.Cells(i, j).Value.ToString() Next dt.Rows.Add(dr) Next
Posted 20 December 2022, 6:13 am EST
Ok,
Can it possible using C1Excel4.8
SKM
Posted 20 December 2022, 6:45 am EST
Hello SKM,
Yes, it can be done also using the C1Excel API as implemented in the attached sample.
Posted 22 December 2022, 8:20 am EST
Thanks, It’s working
Posted 5 January 2023, 1:25 pm EST
Hi Prabhat,
Can you please let me know, how to handle the empty cell because it’s throw exception if any empty cell
Posted 6 January 2023, 1:31 am EST
Hello SKM,
To handle this scenario, you can use the Null-Conditional operator (?) with the GetCell method of Worksheet to check if it contains a null value.
Please find the stripped-down code and modified sample attached.
For i As Integer = 1 To sheet.Rows.Count - 1
For j As Integer = 0 To sheet.Columns.Count - 1
dr(j) = sheet.GetCell(i, j)?.Value.ToString()
Next
dt.Rows.Add(dr)
Next
If you need any other help, please feel free to ask.
ExceltoDT_Demo_VB_mod.zip
Posted 6 January 2023, 11:15 am EST - Updated 6 January 2023, 11:49 am EST
Thanks Prabhat. Can you please have a look why error through in my demo.xlsx fileExceltoDT_Demo_VB.zip
Posted 9 January 2023, 2:21 am EST
For your specific excel file, you first need to evaluate the row count and column count first and then fill in the data accordingly.
We evaluated the first null row in the current sample to get the row count. Please find the attached modified sample for the same.
ExceltoDT_Demo_VB_Mod.zip
