Posted 9 May 2018, 11:07 am EST - Updated 4 October 2022, 2:41 am EST
Creating page image from flexreport using GetImage not working
Posted by: paul on 9 May 2018, 11:07 am EST
Posted 10 May 2018, 1:33 am EST
Hello Paul,
We cannot observe the issue at our end with the attached sample.
Can you please share the report with which you face the issue? Also, share your system environment details along with the ComponentOne version used at your end.Thanks,
MergeFlexReport.zip -
Posted 10 May 2018, 4:06 am EST
Hi Esha,
I have attached a zip file containing the flxr file used along with the vb code to merge. I am trying to merge multiple copies of the same report into a new merged report.
If I run the attached flxr report as in individual report then it displays correctly. When attempting to merge I have exported the page images as png files and these are as the original attachment.
I am using ComponentOne Version 4.0.20173.286 on Windows 10 build 16299.
Paul -
Posted 14 May 2018, 1:59 am EST
Hello Paul,
Thanks for sharing the report and details. We tried using the report in the attached sample and observed some disrupted behavior (see “ReportView.png”). However, the squashed behavior could not be exactly replicated due to the absence of the data. Thus, we request you to share dummy data related to the report so that we can observe the exact issue and escalate it to the concerned team, if the need arises.
Also, we would request you to test your application with the latest 18v1 builds and share the observations.Best Regards,
prj_MergeReports.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-db95f839-8073-48f7-b580-719a022eccfb.png[/img]
