Disable or modify context menu on C1PrintPreviewControl preview pane
Posted by: jong on 19 June 2018, 3:19 pm EST
    Posted 19 June 2018, 3:19 pm EST
    Is there any way to disable or modify items on the right-click context menu on the preview pane of the C1PrintPreviewControl? I am using the C1PrintPreview control on a background worker thread, and if the user clicks the “Copy” item on the context menu, the user receives an error because the thread is not a single threaded apartment thread. Consequently, I need to either disable or trap the Copy command. Can this be done?
    Jon
  • Posted 20 June 2018, 2:01 am EST
    Hello Jon,
    Please try using the below mentioned code snippet for your scenario and let us know if it works:
    C1PrintPreviewControl1.PreviewPane.ContextMenuStrip.Items("Copy").Enabled = False
    Ensure that you set this property in the ContextMenuStrip.Opening event.
    If the issue persists, share your sample application so that we can observe the issue and assist you accordingly.
  • Posted 20 June 2018, 9:39 am EST
    Thanks for the suggestion. Unfortunately, using the code you provided caused a “Object reference not set to an instance of an object” exception. Looking at the context menu items in debug, it would appear that none of the items have a non-empty key. Consequently, an item with the key or name “Copy” did not exist in the collection. I did get it to work with the following code in the ContextMenu.Opening event:
    Dim cnt as integer =  previewControl.PreviewPane.ContextMenuStrip.Items.Count - 1
    For i As Integer = 0 To cnt
         Dim t As ToolStripItem = previewControl.PreviewPane.ContextMenuStrip.Items(i)
         If t.Text = "Copy" Then
              t.Enabled = False
              Exit For
         End If
     Next i
  • Posted 20 June 2018, 11:30 pm EST
    Thanks, Jon.
    Your solution will help the other users as well.
    ~Esha
