Disabling a BackstageViewTab then re-enabling it causes issues
Posted by: agulik on 3 July 2023, 3:43 pm EST
    Posted 3 July 2023, 3:43 pm EST - Updated 3 July 2023, 3:48 pm EST
    Within our application, I would like to disable a BackstageViewTab (in my case called BViewTabUtil) from being accessible. I am able to do this with:
    BViewTabUtil.Enabled = False
    Later, I re-enable it with:
    BViewTabUtil.Enabled = True
    At this point, although the Tab appears enabled in the backstage view, it does not function correctly. Clicking on it does not load the Control into the right-hand panel, and the backstage view enters an odd state where multiple tabs are selected (see screenshot). Exiting the backstage view via the back button and then re-opening it results in the control being loaded/visible in the right-hand panel.
    Is there something needed beyond toggling the .Enabled parameter? I have tried detaching and reattaching the .Control to the BackstageViewTab with no success.
  • Posted 4 July 2023, 5:19 am EST
    We are unable to replicate this issue at our end.
    Could you please provide some more information? When you are enabling and disabling the BackStageViewTab?
    We have created a sample in which we can disable and enable a BackStageView item and it’s working without any issue at our end.
    Please refer the attached sample: BackStageView.zip
    Could you please provide a sample or update the attached sample? So, that we can assist you accordingly.
    Nitin
  • Posted 5 July 2023, 4:42 pm EST - Updated 5 July 2023, 5:17 pm EST
    I was able to reproduce the issue in your code sample by doing the following.
    First, increase the delay time on re-enabling (I did 10 seconds):
    await Task.Delay(10000);
    Then:
    • Run application
    • Go to Utility tab
    • Click button to disable/enable Home Item
    Within the next 10 seconds:
    • Use back arrow to exit backstage view
    • Return to backstage view
    After the 10 seconds elapses, the Home tab becomes enabled again. But, clicking on it does not load the control into the right-hand panel and now both tabs are selected. Backstage view is now in a weird state and the only way to get to the Home tab is hiding/reopening backstage.
  • Posted 6 July 2023, 1:50 am EST
    Thanks for the information.
    We have replicated this issue at our end. This seems like a bug. So, we have escalated this issue to the development team. Will get back to you once we have any update from them.[Internal Tracking Id - C1WIN-30676]
    Nitin
  • Posted 4 August 2023, 2:52 pm EST
    Any update on this one?
  • Posted 7 August 2023, 2:34 am EST
    As per the development team, this issue will be fixed in 2023v3 release. ETA for 2023v3 release is 1st/2nd week of December 2023.
    Nitin
  • Posted 27 December 2023, 3:02 am EST
    This issue is fixed. Please test with the latest version: https://www.nuget.org/packages/C1.Win.Ribbon/8.0.20233.631
    Best regards,
    Nitin
  • Posted 10 January 2024, 1:51 pm EST
    Thank you, I’ve confirmed this fix in our project using 2023v3.
