Posted 30 April 2019, 12:03 pm EST
Esha provided the following code (works great) for rasterizing a .PDF page and displaying it an ImageField so that I could co-mingle the .PDF with other report elements…
I need to delete the images that are created when the form closes and (assuming) I need to dispose of the ImageField to break the connection to the Imge Files so I can do a File.Delete(filename) command.
Setting the objects to Nothing does not resolve the issue… What is the referred process of disposing the Report?
Here’s the code that derives each .PDF page:
C1PdfDocumentSource1.LoadFromFile("\\TCHWhiteCloud\WhiteCloudAttachments\Active Admit Nurses.pdf")
'Create JPEGFilter object
Dim filter As New JpegFilter()
filter.FileName = "../../Images/" & Globals.Username.ToUpper & ".jpg"
C1PdfDocumentSource1.Export(filter)
Dim d As New System.IO.DirectoryInfo(directoryName)
'Dim img As ImageField
For i As Integer = 1 To d.GetFiles.GetUpperBound(0) + 1
img = New ImageField
Dim subSection As SubSection = C1FlexReport1.Sections.Detail.SubSections.Add()
subSection.Visible = True
subSection.Height = C1FlexReport1.Layout.PageSize.Height
subSection.AutoHeight = AutoSizeBehavior.None
img.Top = 0
img.Left = 0
img.MarginTop = 0
img.MarginBottom = 0
img.Height = 1440 * 8.9
img.Width = 1440 * 7.9
'img.AutoHeight = AutoSizeBehavior.GrowAndShrink
'img.AutoWidth = AutoSizeBehavior.GrowAndShrink
img.PictureScale = PictureScaleEnum.Scale
img.BackColor = Color.LightGray
img.Border.Color = Color.Black
img.Border.Style = BorderStyleEnum.Solid
img.Picture = Image.FromFile(Path.Combine(directoryName, Globals.Username.ToUpper & "_page" & i & ".jpg"))
subSection.Fields.Add(img)
Next
