DockingTab CanMove Problem
Posted by: moridi on 7 August 2018, 2:42 pm EST
    Posted 7 August 2018, 2:42 pm EST
    Hello
    CanMoveTabs do not work when MultiLine = true in dockingtab.
  • Posted 8 August 2018, 1:31 am EST
    The issue could not be replicated at our end.
    Please refer the attached sample and gif showing that the tabs still move when C1DockingTab.MultiLine property is set to True with the latest 4.0.20182.314 builds.
    Kindly modify the attached sample so that I can replicate the issue and provide further assistance in the correct manner.
    C1DockingTab_CanMoveTabs.zip
  • Posted 9 August 2018, 1:28 pm EST
    Please see the attachment file
    Add only C1DockingTab and some pages
    set
    CanMoveTabs = True
    MultiLine = True
    that’s it. nothing more.
    set
    CanMoveTabs = True
    MultiLine = True
  • Posted 10 August 2018, 12:09 am EST
    I followed the same way in the sample shared above. Do you observe the issue with it as well?
    I hope you referred the gif attached to my response earlier.
    Also, I could not find the attachment with your response. Please try sharing it again as a zip file.
  • Posted 10 February 2019, 7:45 pm EST
    Hi, when I select the multiline=true, user can not move the tabs at runtime.
  • Posted 11 February 2019, 3:11 am EST
    Please inform if you could replicate the issue with the sample I shared earlier, with the latest 2018 V3 builds: http://prerelease.componentone.com/dotnet40/c1winforms/2018-t3/C1WinForms.4_4.0.20183.343.zip
    Also try attaching your files again in zip format.
    As I could not observe the issue, more information from you on this would help me assist you further.
