Dynamic array and Visualization Functions
Posted by: niels on 2 April 2023, 2:59 am EST
  • Posted 2 April 2023, 2:59 am EST
    I am unable to make the Visualization Functions work with Dynamic Array ‘spilled’ cells. The Paint function is called only on the first cell with the formula.
  • Posted 3 April 2023, 6:03 am EST
    We have created a sample of Visualization Functions with Dynamic Array Spiled Cells. It’s working on our end.
    Please refer to the attached sample for the same: SpillArrayVisualizationDemo.zip
    If you have another use case, then you can update the attached sample to replicate this issue. So, that we can investigate further.
    Also, this forum thread is for C1 Winforms. If you have a Spread Winforms issue then you can generate your forum thread here for better tracking: https://www.grapecity.com/forums/spread-winforms.
    Nitin
  • Posted 3 April 2023, 3:12 pm EST
    Hi Nitin, thank you for answering. I was not clear and will post the follow up question in spread-winforms
  • Posted 4 April 2023, 2:41 am EST
    Apologize for the inconvenience. We will respond to your follow-up question on the Spread-Winforms thread: https://www.grapecity.com/forums/spread-winforms/functionvisualizer-using-parameters-to-create-graphics
    Nitin
