Editor Control: Why is the line spacing double?
Posted by: imgodot on 7 March 2018, 7:41 pm EST
    Posted 7 March 2018, 7:41 pm EST
    When the editor control is in rich-text mode and you press the ENTER key it double-spaces the line.
    If you press SHIFT+ENTER it single-spaces the line.
    How can I make the ENTER key behavior match SHIFT+ENTER?
    – Paul
  • Posted 8 March 2018, 12:02 am EST
    Hi Paul!
    You can check if the user has pressed ENTER key then you need to suppress this and send SHIFT+ENTER keys combination.
    bool suppressNextEnter = true;
    private void C1Editor1_KeyPress(object sender, KeyPressEventArgs e)
                if (e.KeyChar == 13)
                    if (suppressNextEnter)
                        e.KeyChar = (char)0;
                        e.Handled = true;
                    else
                        this.suppressNextEnter = true;
    private void C1Editor1_KeyUp(object sender, KeyEventArgs e)
                if (e.KeyValue == 13 && !e.Shift)
                    e.Handled = true;
                    SendKeys.Send("+{ENTER}");
                    this.suppressNextEnter = false;
    private void C1Editor1_KeyDown(object sender, KeyEventArgs e)
                if (e.KeyValue == 13 && e.Shift)
    Best regards,
    Meenakshi
  • Posted 13 March 2018, 12:49 pm EST
    Meenaksi,
    Thanks for the reply. Note: I was able to implement the specific functionality using just the KeyDown event.
    However, I now have the realization that I still need to allow the user to be able to output a new paragraph (the original ENTER key processing) because, otherwise, the user could not have mixed indents in one control.
    The “normal” ENTER key would create a new paragraph (HTML “
    The “normal” SHIFT+ENTER key would output a newline (HTML “
    I can have ENTER perform a SendKey(<shift+enter>) BUT …
    I was unable to get the normal ENTER processing because it would be translated to SHIFT+ENTER and the code would get into a loop.
    Can you see any way that I can get the ENTER key alone to perform a newline (translating it to a SHIFT+ENTER like your solution above) and also get SHIFT+ENTER or some other key combination to perform the “normal” ENTER processing of creating a new paragraph?
    – Paul
  • Posted 15 March 2018, 4:07 am EST
    Please note we cannot achieve your requirement because this is the designed behavior of C1Editor.
    Hope, it clarifies for you.
    Singh
  • Posted 21 June 2019, 2:51 pm EST
    this is a real issue. is there any other solution. Why make this soo complicated? Is this being fixed? This wasn’t like this in the previous versions.
  • Posted 25 June 2019, 6:38 am EST
    I understand that you still observe this behavior.
    For further investigation, which builds have you been using previously where the behavior was different?
  • Posted 25 June 2019, 9:08 am EST
    Was using version 4.0.20132.203 on VS2013 now using version 4.0.20182.314 on VS2017.
  • Posted 25 June 2019, 9:31 am EST
    version 2.0.20132.203 was also working fine.
  • Posted 27 June 2019, 12:31 am EST
    I have responded to the case on related SupportOne ticket #386166.
    Please refer the same.
