Error C1DateEdit when click outSide calendar
Posted by: anhvu.le on 24 August 2018, 5:10 am EST
    Posted 24 August 2018, 5:10 am EST
    Hi all,
    I used C1dateEdit 2013 on WinForm. I have form with Name is frmUser, this form used C1DateEdit (ex: c1dateBirthday). When i run this Form, I click c1dateBirhday but not click Calender, I click this form (outside Calender). This form is hidden on the desktop.
    I help me fix error.
    Thanks ALL.
  • Posted 27 August 2018, 2:03 am EST
    A lot of changes have been made to the controls since 2013 and hence, this issue is not observed with the latest 18v2 build: 4.0.20182.314 (http://prerelease.componentone.com/dotnet40/c1winforms/2018-t2/C1WinForms.4_4.0.20182.318.zip).
    Request you to use C1DateEdit of the mentioned version and let me know in case you face any issue. To use the build, follow the below mentioned steps:
    1. Extract the build downloaded.
    2. Right click in the Toolbox. Select “Add Tab”. Give a name to the tab.
    3. Right click in that tab, select “Choose Items”. “Choose Toolbox Items” dialog appears.
    4. Click on Browse. Move to the location where you have extracted the build.
    5. Select the dll whose related controls you wish to add to the Toolbox.Click Open.
    6. Finally, click OK in the “Choose Toolbox Items” dialog.
  • Posted 27 August 2018, 3:34 am EST
    Also note that the C1DateEdit componet was completely rewritten and the new version should be used now. The new version is found in the class “C1.Win.Calendar.C1DateEdit” in the DLL “C1.Win.Calendar.4”. The API should be compatible to the old control.
  • Posted 27 August 2018, 5:16 am EST
    Thanks esha.dhir,
    We can’t build all project. We have more 1000 dll and framework. Old and new controls will cause errors. I want to know if there is a control attribute to fix this error, or something similar.
    Best regards.
    Le Anh Vu
  • Posted 28 August 2018, 5:25 am EST
    I understand your concern. But unfortunately, there is no way to resolve this in the old version.
    Apologies for the inconvenience.
  • Posted 29 August 2018, 4:27 am EST
    Thanks esha.dhir,
    Only one customer we reflect on this error. We will not fix this.
  • Posted 30 August 2018, 2:47 am EST
    The bug fixes are made in the builds that come after the issue is observed.
    Sorry, but there is no other way to resolve this in the 2013 version.
