Posted 7 April 2021, 2:37 pm EST
All I am getting is our tech are working on it since December 2020.
Service is so poor. I received my renewal notice today and am really disappointed with the service. I have been renewing for the last 20 years.
Here is what started happening after the last update in before xmas last year. All I am getting is that its Microsoft issue and Microsoft is saying its not their issue. Following is my message to support in December and since then all I am getting is its been escalated and will let you know.
I updated Componentone yesterday and now am getting errors of duplication in all my apps that uses componentone. Get the following in VS 2019.
All my apps were working fine until I updated. I uninstalled componentone and did a fresh install and no changes
Below is what I am getting. I cant change this. My apps are in Vb.Net
Need help asap.
Sunil
Building file ‘C:\TruckRepair\TRS\TRS SYSTEM\Release\TRS.msi’…
WARNING: ‘System.Xml.XDocument.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.XDocument\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Xml.XDocument.dll’ is under Windows System File Protection.
WARNING: ‘System.Xml.ReaderWriter.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.ReaderWriter\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Xml.ReaderWriter.dll’ is under Windows System File Protection.
WARNING: ‘System.Collections.Concurrent.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Collections.Concurrent\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Collections.Concurrent.dll’ is under Windows System File Protection.
WARNING: ‘System.Runtime.Serialization.Json.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization.Json\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Json.dll’ is under Windows System File Protection.
WARNING: ‘System.Runtime.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.dll’ is under Windows System File Protection.
WARNING: ‘System.Net.Http.WebRequest.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Net.Http.WebRequest\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.Http.WebRequest.dll’ is under Windows System File Protection.
WARNING: ‘System.IO.Compression.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IO.Compression\v4.0_4.0.0.0__b77a5c561934e089\System.IO.Compression.dll’ is under Windows System File Protection.
WARNING: ‘System.Diagnostics.Tools.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Diagnostics.Tools\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Diagnostics.Tools.dll’ is under Windows System File Protection.
WARNING: ‘System.Threading.Tasks.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Threading.Tasks\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Threading.Tasks.dll’ is under Windows System File Protection.
WARNING: ‘System.Threading.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Threading\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Threading.dll’ is under Windows System File Protection.
WARNING: ‘System.IO.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IO\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.IO.dll’ is under Windows System File Protection.
WARNING: ‘System.Diagnostics.Tracing.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Diagnostics.Tracing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Diagnostics.Tracing.dll’ is under Windows System File Protection.
WARNING: ‘System.Diagnostics.Debug.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Diagnostics.Debug\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Diagnostics.Debug.dll’ is under Windows System File Protection.
WARNING: ‘System.Runtime.InteropServices.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.InteropServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.InteropServices.dll’ is under Windows System File Protection.
WARNING: ‘System.Text.Encoding.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Text.Encoding\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Text.Encoding.dll’ is under Windows System File Protection.
WARNING: ‘System.Dynamic.Runtime.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Dynamic.Runtime\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Dynamic.Runtime.dll’ is under Windows System File Protection.
WARNING: ‘System.Linq.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Linq\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Linq.dll’ is under Windows System File Protection.
WARNING: ‘System.Net.Http.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Net.Http\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.Http.dll’ is under Windows System File Protection.
WARNING: ‘System.Runtime.Extensions.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Extensions\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.Extensions.dll’ is under Windows System File Protection.
WARNING: ‘System.Reflection.Primitives.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Reflection.Primitives\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Reflection.Primitives.dll’ is under Windows System File Protection.
WARNING: ‘System.Resources.ResourceManager.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Resources.ResourceManager\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Resources.ResourceManager.dll’ is under Windows System File Protection.
WARNING: ‘System.Reflection.Extensions.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Reflection.Extensions\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Reflection.Extensions.dll’ is under Windows System File Protection.
WARNING: ‘System.Collections.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Collections\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Collections.dll’ is under Windows System File Protection.
WARNING: ‘System.Globalization.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Globalization\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Globalization.dll’ is under Windows System File Protection.
WARNING: ‘System.Linq.Expressions.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Linq.Expressions\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Linq.Expressions.dll’ is under Windows System File Protection.
WARNING: ‘System.Threading.Tasks.Parallel.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Threading.Tasks.Parallel\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Threading.Tasks.Parallel.dll’ is under Windows System File Protection.
WARNING: ‘System.Reflection.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Reflection\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Reflection.dll’ is under Windows System File Protection.
WARNING: ‘System.Runtime.Numerics.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Numerics\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.Numerics.dll’ is under Windows System File Protection.
WARNING: ‘System.IO.Compression.FileSystem.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IO.Compression.FileSystem\v4.0_4.0.0.0__b77a5c561934e089\System.IO.Compression.FileSystem.dll’ is under Windows System File Protection.
WARNING: ‘System.Text.Encoding.Extensions.dll’ should be excluded because its source file ‘C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Text.Encoding.Extensions\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Text.Encoding.Extensions.dll’ is under Windows System File Protection.
WARNING: Two or more objects have the same target location (‘[targetdir]\system.runtime.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.io.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.collections.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.xml.xdocument.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.runtime.extensions.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.text.encoding.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.resources.resourcemanager.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.runtime.serialization.json.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.diagnostics.tools.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.reflection.extensions.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.linq.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.reflection.primitives.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.text.encoding.extensions.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.linq.expressions.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.reflection.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.collections.concurrent.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.threading.tasks.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.xml.readerwriter.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.runtime.numerics.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.threading.tasks.parallel.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.globalization.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.net.http.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.dynamic.runtime.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.runtime.interopservices.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.diagnostics.debug.dll’)
WARNING: Two or more objects have the same target location (‘[targetdir]\system.threading.dll’)
