Error in loading C1PrintPreviewControl
Posted by: a.callegari on 30 January 2019, 8:11 am EST
    Posted 30 January 2019, 8:11 am EST
    When creating the form containing the C1PrintPreviewControl control, the error is generated:
    System.InvalidOperationException
    HResult = 0x80131509
    Message = Error creating the form. Error: Could not load file or assembly ‘C1.C1Report.2, Version = 2.6.20132.54638, Culture = neutral, PublicKeyToken = 594a0605db190bb9’ or one of its dependencies. The manifest definition of the specified assembly does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Origin = can not be evaluated
    Stack analysis:
    <Exception stack analysis can not be evaluated
    Internal exception 1:
    FileLoadException: Unable to load file or assembly ‘C1.C1Report.2, Version = 2.6.20132.54638, Culture = neutral, PublicKeyToken = 594a0605db190bb9’ or one of its dependencies. The manifest definition of the specified assembly does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Internal exception 2:
    FileLoadException: Unable to load file or assembly ‘C1.C1Report.2, Version = 2.0.20182.314, Culture = neutral, PublicKeyToken = 594a0605db190bb9’ or one of its dependencies. The manifest definition of the specified assembly does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    All C1 controls are with release 2.0.20182.314
  • Posted 31 January 2019, 12:56 am EST
    Please refer the solution stated for the mentioned error, in this blog post:
    https://www.grapecity.com/en/blogs/a-step-ahead-troubleshooting-common-errors-part-i
    In case the issue persists, do let us know.
    Note: .Net Framework 2.0 Support Notice (https://www.grapecity.com/en/forums/winforms-edition/net-framework-20-support-n_5)
  • Posted 1 February 2019, 6:11 am EST
    I deleted the references, the bin and obj folders, reloaded everything, but the error continues
  • Posted 1 February 2019, 7:04 am EST
    I found the problem, in app.config:
    <runtime>
    	<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
    		<dependentAssembly>
    			<assemblyIdentity name="C1.C1Report.2" publicKeyToken="594A0605DB190BB9" culture="neutral" />
    			<bindingRedirect oldVersion="0.0.0.0-2.6.20132.54638" newVersion="2.6.20132.54638" />
    		</dependentAssembly>
    	</assemblyBinding>
    </runtime>
    I simply deleted the text (see above) from app.config
    I mark it that can be of help to others
    Alberto
