Evaluating FlexReport
Posted by: fabio.lavitola on 8 February 2022, 1:12 pm EST
    Posted 8 February 2022, 1:12 pm EST
    Hi, I’m evaluating the latest WinForm using FlexReport into an old VMWare Machine.
    I’m trying to use a FlexChartField with Histogram into a FlexReport but - even if I’vent found any Sample - I still cannot view any data.
    The FlexChartFiled set with Histogram CharType seems to be the only Chart Type with issues…
    Any hint?
    I’ve also tried an existing sample you provided using the installed samples, and only Legacy C1Chart in FlexReport seems to work, but I’d like to understand the newver Chart versione (FlexChartField).
    Any Idea?
    Fabio
  • Posted 9 February 2022, 7:02 am EST
    We have replicated this behavior at our end, and this seems like a bug. So, we have escalated it to the development team. We will get back to you once we have any update from them. [Internal Tracking Id - C1WIN-26781]
    Nitin.
  • Posted 9 February 2022, 2:14 pm EST
    Thanks for your support, 'cause I’m waiting for this solution to purchase a license…
    I also expect the FlexChartField Normal Curve, exactly as it is drawn into standard FlexChart (and works correctly)…
  • Posted 11 February 2022, 1:57 am EST
    We are discussing your requirement to the development team on priority basis.
    We will get back to you once we get any update from them.
    Nitin
  • Posted 15 February 2022, 1:24 am EST
    Thanks for your patience.
    The histogram type is not implemented in current version’s FlexChartField. We are planning to implement this feature to 2022v2 release.
    So, sorry to inform you that we can’t implement Histogram FlexChartField in Reports right now. We request you to wait till the feature is implement on FlexChartFiled.
    Nitin
  • Posted 15 February 2022, 4:01 am EST
    Can u give me approx when it will be released? In days ? Weeks? Mnths? Year?
    My clients won’t wait so long…
  • Posted 15 February 2022, 5:01 am EST
    2022v2 release is approximately at the end of July, 2022. You can wait for this feature till release i.e., July 2022.
    Nitin
  • Posted 18 February 2022, 7:27 am EST
    Perfect, I’ll wait for that release in order to place the order of a brand new WinForms License.
    Thanks for your feedback.
    Fabio La Vitola
  • Posted 11 July 2022, 1:20 pm EST
    Hi, I’d like to get an extended of 2022V2 Trial Key to test .Net Core 6 if possibile, 'cause since I’m waiting for 2022V3 realease, meanwhile I’d like to test my migrations…
    Thanks in advance
  • Posted 12 July 2022, 4:45 am EST
    JFYI, 2022v2 is not publicly released yet. We can provide the trial extension for 2022v2 after the release. As this feature will be fixed in 2022v2 and publicly available at the end of July 2022. You can test the fix after 2022v2 release with trial license.
    On other hand, let we discuss with the development team for an update on this issue.
    You have mentioned 2022v3, where development is not started yet for this. We need to release 2022v2 first. Is there any issue posted by you, which will be fixed in 2022v3?
    Any specific reason to wait for 2022v3 release.
    Nitin.
  • Posted 13 July 2022, 2:58 am EST
    Sorry Nitin, I wrote the wrong version reference.
    At the moment I’d like to test my conversions in .Net Core 6, doesn’t matter the version (2022V2 is coming), the current version 2022V1 should be ok, waiting for the next 2022V2.
    Thanks in advance
  • Posted 13 July 2022, 7:52 am EST
    We have created a new case for you. Where the trial license key is shared. For security reasons we can’t share the license key here.
    You can refer here : https://www.grapecity.com/my-account/my-support/case/3a734ead-9d02-ed11-82e4-000d3a9c6fd8
    JFYI, This key will work for any version but valid for 30 days from the day you activate.
    Nitin
  • Posted 12 August 2022, 10:42 am EST
    Hi, even in 2022V2 I can’t draw Histogram in FlexChartReport.
    In a FlexChart I have to add an Histogram Series with
    C1FlexChart.Series.Add(New Histogram)
    , but with FlexChartField i cannot do that…
    Can U provide me a sample, please, possibily in VB.Net?
    Fabio
  • Posted 16 August 2022, 12:34 am EST
    Hi Fabio,
    We have already informed you here: https://www.grapecity.com/my-account/my-support/case/3a734ead-9d02-ed11-82e4-000d3a9c6fd8
    That this fix will not available in 2022 Major Release. But we will fix this issue in 2022v2 Hotfix. So that it will be available between 2022v2 and 2022v3.
    2022v2 hotfix is in a QA cycle. If everything fine with the QA side, then it will take two weeks to release. Otherwise, it will take some more time. But don’t worry it will be available before 2022v3. It won’t take too long.
    Nitin.
  • Posted 14 December 2022, 10:43 am EST
    Hi Nitin,
    where can i find the latest release complete changelog?
    Fabio
  • Posted 15 December 2022, 2:58 am EST
    Hi Fabio,
    You can find the Winforms Changelog at location : C:\Program Files (x86)\ComponentOne\WinForms Edition
    Nitin
  • Posted 24 February 2023, 11:07 am EST
    Hi all,
    FlexReport Histograms & Normal Curve are NOW just PERFECT!
    Ty all!!!
