Export to PDF using FlexReport Path Format not supported
Posted by: saidnai on 28 March 2019, 8:10 am EST
    Posted 28 March 2019, 8:10 am EST
    Dear all,
    I have used the following code in VB as suggested in one Topic to create a PDF file from a Flexreport in silent mode:
    Dim c1FlexReport1 As New C1FlexReport()
    c1FlexReport1.Load(“C:\Test\Shiftreport.flxr”, “Shiftreport”)
    c1FlexReport1.Render()
    Dim filter As New C1.Win.C1Document.Export.PdfFilter()
    filter.ShowOptions = False
    filter.FileName = “Shiftreport” + “C:\Temp\Shiftreport.pdf”
    c1FlexReport1.RenderToFilter(filter)
    Unlikely i get an error saying “The path format is not supported”
    Can you please give a running sample for this issue.
    Said
  • Posted 29 March 2019, 2:24 am EST
    Hello Said,
    The problem lies here:
    “Shiftreport” + “C:\Shiftreport.pdf”
    This generates an invalid path, something like:
    “Shiftreport C:\Temp\Shiftreport.pdf”
    You can instead use the path, as follows:
            filter.FileName = "C:\Temp\Shiftreport.pdf"
    A sample has been attached for your reference.
    prj_FlexReport_PdfExport.zip
