Filter Column Size
Posted by: philippe.berhin on 29 July 2021, 11:23 am EST
  • Posted 29 July 2021, 11:23 am EST
    Is there a way to change the filter column window size ?
  • Posted 30 July 2021, 12:25 am EST
    You can use the MouseClick event to know when the FilterIcon is clicked and then use the OpenForms property of the Application to get the opened filter editor form. Once you have the form, you can customize it as you want.
    Please refer to the sample attached.
    Avnish
    FlexGridFilterFormSize.zip
  • Posted 30 July 2021, 3:10 am EST
    Hi Avnish
    Perfect. Thanks for the solution
    By the way, is there any known release date for the 2021v2 ?
  • Posted 30 July 2021, 8:10 am EST
    Correction: In Fact the code in the FlexGridFilterFormSize works partially
    The maximum size seems to be 440 (width) on 328
    So if you have long text in on column, user still have to scroll horizontally
  • Posted 30 July 2021, 8:24 am EST
    Works if you set the Maximum Size before
    frm.MaximumSize = new Size(800, (int)(c1FlexResult.Height * 0.8));
    frm.Width = 800;
    frm.Height = (int)(c1FlexResult.Height * 0.8);
  • Posted 2 August 2021, 1:22 am EST
    Glad, we could help.
    The ETA for the 21v2 release is 4th August 2021.
    Avnish
