FilterBar synchronization
Posted by: kshitizkumar on 3 July 2019, 10:15 am EST
    Posted 3 July 2019, 10:15 am EST
    I am using two grids in the same form and it has two filter bars. If I search for some value in the filter-bar, I want the second grid to show data corresponding to the result.(for eg, if result get row from index 1 , second grid should also select row at index 1 and vice-versa) Is there a way to synchronize the filter-bar to do that ?
    Kshitiz
  • Posted 5 July 2019, 3:30 am EST
    Hello Kshitiz,
    First of all sorry for the late reply.
    There is no way to synchronize the filter bar of two different TrueDb’s . But you can use the DataSource of the filtered Grid to get the index of the rows that has to be shown on the other Grid.
    I have implemented this in the attached sample. Please go through this to understand in a better way.
    Thanks and Regards,
    TrueDbGridFilterBarDemo.zip
  • Posted 8 July 2019, 9:24 am EST
    Thanks Prabhat for the workaround. I think I can use this.
