Flex Report Designer High DPI Support
Posted by: paul on 24 April 2018, 11:04 am EST
    Posted 24 April 2018, 11:04 am EST
    Is there any way I can get the FlexReport designer to scale up to a 4K screen? I have the source code embedded in my application and the sections and data fields look tiny, making the designer almost impossible to use.
    Paul
  • Posted 25 April 2018, 6:09 am EST
    Hello Paul,
    We opened C1FlexReportDesigner on a machine with 3840x2160 resolution and the sections and fields appeared normally for the reports.
    Could you please share the screenshots of the observations along with the system environment details and the designer version being used at your end? This will help us understand the issue further and escalate if the need arises.
  • Posted 25 April 2018, 6:23 am EST - Updated 4 October 2022, 1:22 am EST
    Hi Esha,
    Attached is a screen shot of the report designer on my 3840x2160 resolution screen running 250% display scaling. As you can see the fields are extremely small, as are all the sections. In some cases the sections are overlapping each other.
    I am not running the standalone designer as this doesn’t give me the flexibility I need loading and saving report definitions to and from a database. Also the standalone designer doesn’t attempt so scale, it simply stretches the interface making it look blurry. I have embedded the source code into my application and am calling this in code from within my application.
    Paul
  • Posted 26 April 2018, 1:40 am EST
    Hello Paul,
    Thanks for sharing the screenshot and the details.
    We are discussing the issue with the concerned team (Internal Tracking ID: 319402) and will get back to you once it is done.
  • Posted 26 April 2018, 2:38 am EST
    Hi Esha,
    For further information, I have Per Monitor High DPI switched on in my application and all forms are set to AutoScaleMode.Font.
    Paul
  • Posted 26 April 2018, 4:22 am EST
    Thanks for the information, Paul.
    We’ll keep this in mind.
  • Posted 8 May 2018, 8:49 am EST
    Has there been any progress on this Esha?
    Paul
  • Posted 9 May 2018, 12:33 am EST
    Hello Paul,
    We are getting in touch with the team for an update and will get back to you as soon as we hear from them.
  • Posted 12 June 2018, 9:34 am EST
    Hi Esha,
    Has there been any update on this?
    Paul
  • Posted 13 June 2018, 5:10 am EST
    The ETA for the fix is end of June. We will let you know once the build containing the fix is released.
  • Posted 8 August 2018, 8:52 am EST
    Hi Esha,
    Is there any update on this?
    Paul
  • Posted 10 August 2018, 6:50 am EST
    Hello Paul,
    I am discussing this with the development team and will get back to you as soon as it is done.
  • Posted 5 December 2018, 10:54 am EST
    Hi Esha,
    Has there been any update on this? We now have customers complaining that they can’t modify the report layouts on their 4k screens
    Paul
  • Posted 9 December 2018, 11:20 pm EST
    Paul,
    I have asked the development team to provide an urgent update on this. Will soon get back to you with a response.
    Apologies for the inconvenience.
  • Posted 12 March 2019, 10:25 am EST
    Hi Esha,
    Paul
  • Posted 20 March 2019, 2:23 am EST
    Hello Paul,
    The developers are currently working on this. We should have an update by the end of this month.
    Thank you for your patience.
  • Posted 4 April 2019, 1:15 am EST
    Hi Paul,
    The team cannot reproduce the issue with the designer using a hi-resolution monitor.
    As we understand that the original issue has been with your app where you use the designer control, please provide a sample that we can build and run. If you want to share it privately, you can create a case on SupportOne: https://supportone.componentone.com
    Also, please share more information about your display settings.
    Regards.
