FlexChart: AxisX.ActualMax or Min strange values question
Posted by: a.sharov on 4 November 2021, 2:34 pm EST
    Posted 4 November 2021, 2:34 pm EST
    Hi.
    I have code wich generate data with current date and bind it to chart
                flexChart3.DataSource = _data;
                var xCoord = new Series
                        Name = "X",
                        Binding = "X",
                        BindingX = "Date",
                        ChartType = ChartType.LineSymbols,
                flexChart3.Series.Add(xCoord);
    Date component is hourly values for some period:
            public List<XPosition> GetXVals()
                var list = new List<XPosition>();
                var now =  DateTime.UtcNow;
                var after = now.AddMonths(3); //now.AddYears(1);
                var x = 1000;
                //2886336.6267
                var rand = new Random();
                while(now < after)
                    list.Add(new XPosition
                            Date = now,
                            X = (temp % 2 == 0 ? 1 : -1) * temp / 10000.0,
                    now = now.AddHours(1);
                return list;
    For AxisX of the chart I see value for ActualMax like 44596.746771481485. I figured out that this values i s a number of days since 1900 (1/1/1900). Well, I simply generated data from 1/1/1900 and values was like 1,2,3,4,.
    Is it correct? Is there any documentation for that?
    Thanks in advance.
  • Posted 11 November 2021, 12:47 am EST
    Hi Anton,
    I hope you got the solution from here:
    https://www.grapecity.com/forums/winforms-edition/range-selector-and-aggreat
    JFYI, DateTime values can’t be plotted to a chart. So, C1FlexChart uses the OLE representation of date. You can refer to the same from MSDN docs:
    https://docs.microsoft.com/en-us/dotnet/api/system.datetime.tooadate?view=netframework-4.5.2
