Posted 1 March 2022, 9:37 am EST - Updated 3 October 2022, 10:37 pm EST
FlexChart - Draw vertical line with text
Posted by: dirk.kuehnle on 1 March 2022, 9:37 am EST
Posted 2 March 2022, 2:06 am EST
Hi Dirk,
Thank you for sharing the snapshot.
You can implement this requirement using IRenderEngine’s DrawLine/DrawString method inside FlexChart’s Rendered event as follows:
private void OnFlexChartRendered(object sender, RenderEventArgs e) { var dataItem = _chartvalues[3]; // line drawing var x = AxisX.Convert(dataItem.Date.ToOADate()); // convert data coordinates to chart coordinates. var yMin = AxisY.Convert(((IAxis)AxisY).GetMin()); var yMax = AxisY.Convert(((IAxis)AxisY).GetMax()); e.Engine.SetStroke(Brushes.Blue); e.Engine.SetStrokeThickness(1); e.Engine.DrawLine(x, yMin, x, yMax); // text drawing var textX = x + 10; var textY = Math.Abs((yMax - yMin) / 2); e.Engine.SetFont(new Font("Segoe UI", 10, FontStyle.Italic)); e.Engine.SetStroke(Brushes.Blue); e.Engine.DrawString("Sample Text", new _Point(textX, textY)); }
Please refer to the same from the attached sample. (see FlexChartDraw.zip)
Posted 2 March 2022, 5:21 am EST
Hi Kartik,
your solution works perfect for me.
I have an additional question: Is it posssible drawing the line dotted?
Best regards,
Dirk -
Posted 2 March 2022, 7:22 am EST
Hi Dirk,
You can use IRenderEngine’s SetStrokePattern method before drawing the line as follows:
e.Engine.SetStrokePattern(new double[] { 1, 2 }); // set line pattern e.Engine.DrawLine(x, yMin, x, yMax);
Kartik -
Posted 2 March 2022, 7:37 am EST
Hi Kartik,
your solution works for me again.
I thought to use SetStrokePattern but I didn’t know how to parameterize the double-parameter.
Thanks and best regards,
Dirk -
Posted 2 March 2022, 7:44 am EST
Hi Kartik,
now I have another problem.
If the chart is exported as .svg, the text of the vertical line is missing in the image.
.png and .jpg exports ar working fine.Regards,
Dirk -
Posted 3 March 2022, 12:29 am EST
Hi Dirk,
This behavior seems like a bug. So, we have escalated it to the devs and will get back to you when there is any update. [Internal Tracking Id - C1CHART-2007]
Kartik -
Posted 3 March 2022, 8:10 am EST
Hi Dirk,
As per the devs, we need to use IRenderEngine’s SetFill method before drawing string as follows:
e.Engine.SetFill(Brushes.Blue); e.Engine.DrawString("Sample Text", new _Point(textX, textY));
However, there is still an issue where the applied font is not honored in the exported SVG and it will be fixed in the 2022v1 hotfix build. We will let you know once the hotfix build is released.
Kartik -
Posted 4 March 2022, 7:00 am EST - Updated 3 October 2022, 10:37 pm EST
Hi Kartik,
thanks a lot therefore.
Maybe I found another bug…
I draw 3 vertical, dotted lines 2 x green, 1 x blue, as you can see in attached image.
First green line with date december, 11th 2018 seems to be at the correct x-position in diagramm.
Second green line with date april, 13th 2021 isn’t at the correct x-position. The line is drawn before “04/2022”-unit of x-axis.
The position of the blue line with date march, 04th 2022 seems also not to be correct.Best regards,
Dirk -
Posted 7 March 2022, 1:08 am EST
Hi Dirk,
However, we couldn’t replicate this behavior at our end. Could you please share a small working sample replicating this behavior so we can assist you accordingly?
