Posted 16 January 2023, 5:33 am EST
We do not need to show any content of the LineMarker.
Is there a way do disable any content? Setting the content to null sttill shows a square.
Posted by: r.zeller on 16 January 2023, 5:33 am EST
Posted 17 January 2023, 7:12 am EST
Hi Ralf,
Unfortunately, we could not replicate the issue on our end. We have created a sample application for your reference. (See HideLineMarkerContent.zip)
Please note that the sample is created using the latest build(version 4.6.20223.777). We recommend that you update to the latest version of the control if you are using the older versions.
In case your requirement differs from our understanding, we request you update the sample accordingly so that we can replicate the issue on our end.
Thanks & Regards,
Aastha
Posted 26 January 2023, 5:41 am EST - Updated 26 January 2023, 5:46 am EST
Hi Aastha,
our project uses framework 4.0 so I’ve updated the controls to 4.0.20222.566 which seems to be the latest version supporting this framework. The behaviour is the same.
Unfortunately I cannot test your project because we have only the WinForms license.
I’ve attached the C1 Linemarker Sample Code where I just set the linemarker content empty. In the attached picture you can see the result with the linemarker and an orange line. The linemarker content still seems to draw an empty rectangular shape which can be seen as an overlay on the orange line.
Posted 27 January 2023, 4:45 am EST
Hi Ralf,
We could replicate the issue on our end. This seems to be a bug to us. Hence we have escalated the issue to the devs. [Internal tracking ID: C1WIN-28973]
We will update you on this as soon as we hear back from the developers.
Thanks & Regards,
Aastha
Posted 20 April 2023, 1:36 am EST
Hi Ralf,
We are glad to inform you that the issue has been resolved in the latest build 2023v1. Please update your controls to 4.8.20231.596 build version in order to eliminate the issue at your end.
Thanks & Regards,
Aastha
