Posted 4 June 2024, 11:53 am EST
- Updated 4 June 2024, 11:58 am EST
I changed my code in this way:
private bool plot_Trend()
bool exitResult = true;
string toolTipLineMaker = “”;
System.Windows.Forms.Cursor.Current = System.Windows.Forms.Cursors.WaitCursor;
try
string colName = _AnaComboDataTypeList.Where(q => q.Id == ((comboBoxElement)cbDataType.SelectedItem).id).FirstOrDefault().ColumnName; // “dt_value”;
string firstAvgTableName = _AnaComboAvgTypeList[0].TableName;
_fChart.AxisX.Min = _fChart.AxisX.Max = double.NaN;
if (cbAvgType.SelectedIndex == 0)
_fChart.AxisY.Min = _fChart.AxisY.Max = double.NaN;
else
_fChart.AxisY.Min = 0;
//_fChart.AxisY.Max = 1000;
_fChart.AxisX.LabelAngle = -45; // range da -90 a + 90
//_fChart.AxisX.OverlappingLabels = OverlappingLabels.Auto;
//_fChart.AxisX.StaggeredLines = 2; // su quante linee mostra le etichette dei valori
_fChart.Legend.Position = Position.Right;
_fChart.Series.Clear();
_fChart.ChartType = ChartType.Line; // LineSymbols
if (cbChartType.SelectedIndex == 1)
_fChart.AxisY.AxisLine = false;
_fChart.Legend.Position = Position.None;
tmrReal.Enabled = false;
tmrReal.Stop();
createDataSource(colName);
//Binding chart's AxisX to 'Date' so Dates are shown in Horizontal axis
_fChart.BindingX = "dt_date";
toolTipLineMaker = toolTipLineMaker + "{dt_date}\r\n";
//Adding a Series to chart and binding it (AxisY)
int AxisY = 0; string seriesName;
double allMax = _minMaxList.Max(q=> q.MaxFromDB);
_fChart.AxisY.Max = allMax;
foreach (WasMeasures selected in _ListaParametriSelezionati)
seriesName = selected.CMStationCode + " - " + selected.C3 + " [" + selected.C4 + "]";
_fChart.ToolTip.Content = _fChart.ToolTip.Content + seriesName + "\r\n";
// Assi diversi per ogni serie con min e max: sembra creare confusione !!
//_fChart.Series[AxisY].AxisY = new Axis { Position = Position.Left }; //, Min = Convert.ToDouble( selected.C8) , Max = Convert.ToDouble(selected.C10)};
if (cbChartType.SelectedIndex == 0)
_fChart.Series.Add(new C1.Win.Chart.Series { Name = (seriesName), Binding = selected.CMStationCode+"#"+selected.C2 });
Position = (AxisY == 0 ? Position.Left : Position.None),
Min = Convert.ToDouble(0),
Max = Convert.ToDouble(100)
else
AxisY_MinMaxValues measSelected = _minMaxList.Where(q => q.C2 == selected.C2 && q.StationCode == selected.CMStationCode).FirstOrDefault();
if (allMax<measSelected.MaxFromDB)
allMax = measSelected.MaxFromDB;
_fChart.Series.Add(new Series
Binding = selected.CMStationCode+"#"+selected.C2,
Name = seriesName,
AxisY = new Axis
Position = Position.Left,
//Max = measSelected.MaxFromDB,
Title = measSelected.name,
Style =
StrokeColor = Color.FromArgb((int)(_fChart as C1.Chart.IPalette).GetColor(AxisY))
AxisY++;
// Aggiunta per la finta scala a destra
_fChart.Series.Add(new C1.Win.Chart.Series { Name = (""), Binding = "hidden_Col" });
Position = (_ListaParametriSelezionati.Count > 1 ? Position.Right : Position.None),
_fChart.Series[0].AxisY.MajorGrid = true;
//else
// _fChart.AxisY.Max = allMax;
txtZoom.Enabled = _ListaParametriSelezionati.Count > 1 && cbChartType.SelectedIndex == 0 ? true : false;
btnZoom.Enabled = _ListaParametriSelezionati.Count > 1 && cbChartType.SelectedIndex == 0 ? true : false;
// Limit series 20211104 : il limite di legge va messo solo se ho una sola misura !!!
double maxValue = 0;
if (_ListaParametriSelezionati.Count == 1)
//Creating and adding TrendLine series
TrendLine _trendLine = new C1.Win.Chart.TrendLine();
string Cx = "";
switch (_AvgTypeSelected.TableName.ToUpper())
case "WDS_HALF":
Cx = _ListaParametriSelezionati[0].C28 == null ? "0" : _ListaParametriSelezionati[0].C28.Replace(".", ",");
break;
case "WDS_ELAB":
Cx = _ListaParametriSelezionati[0].C30 == null ? "0" : _ListaParametriSelezionati[0].C30.Replace(".", ",");
break;
case "WDS_DAYS":
Cx = _ListaParametriSelezionati[0].C31 == null ? "0" : _ListaParametriSelezionati[0].C31.Replace(".", ",");
break;
case "WDS_MONTH":
Cx = _ListaParametriSelezionati[0].C33 == null ? "0" : _ListaParametriSelezionati[0].C33.Replace(".", ",");
break;
case "WDS_YEAR":
Cx = _ListaParametriSelezionati[0].C57 == null ? "0" : _ListaParametriSelezionati[0].C57.Replace(".", ",");
break;
case "BFMYYYYMMDD":
if (firstAvgTableName == "WDS_HALF")
else
break;
_trendLine.Name = "ELV " + _ListaParametriSelezionati[0].C3 + ": " + Cx;
maxValue = Convert.ToDouble(Cx);
List<double> levels = _dtExcel.AsEnumerable().Select(al => al.Field<double>(1)).Distinct().ToList();
double max = levels.Max();
_trendLine.AxisY = new Axis { Position = Position.None, Min = Convert.ToDouble(0), Max = ((maxValue < max) ? Convert.ToDouble(max) : Convert.ToDouble(maxValue + 1)) };
if (maxValue > max)
_fChart.Series[0].AxisY.Max = Convert.ToDouble(maxValue + 1);
_trendLine.Binding = _ListaParametriSelezionati[0].CMStationCode + "#" + _ListaParametriSelezionati[0].C2 + "_sup";
_trendLine.Order = 4;
_trendLine.Style.FillColor = _fChart.Series[0].Style.FillColor; //Color.AntiqueWhite;
_trendLine.FitType = FitType.AverageY;
if (maxValue > 0) _fChart.Series.Add(_trendLine);
/* // Tolti per permettere il tooltip personalizzato
if (!_firstPlot && lineMarker != null) lineMarker.Remove();
Font lineMarkerFont = new Font(FontFamily.GenericSansSerif, 8);
lineMarker = new C1.Win.Chart.Interaction.LineMarker(_fChart);
lineMarker.Lines = C1.Win.Chart.Interaction.LineMarkerLines.Both;
lineMarker.VerticalPosition = 0.2;
lineMarker.HorizontalPosition = 0.3;
lineMarker.Alignment = C1.Win.Chart.Interaction.LineMarkerAlignment.Right;
lineMarker.ForeColor = Color.Black;
lineMarker.Font = lineMarkerFont;
lineMarker.Interaction = C1.Win.Chart.Interaction.LineMarkerInteraction.Move;*/
//lineMarker.Content = toolTipLineMaker.Substring(0, toolTipLineMaker.Length - 2);
// _fChart.LegendToggle = true;
// Scroll X
if (!_firstPlot)
if (_horizontalScrollbar != null) _horizontalScrollbar.Remove();
//if (_verticalScrollbar != null) _verticalScrollbar.Remove();
_horizontalScrollbar = null;
//_verticalScrollbar = null;
_fChart.Rendering += (s, e) =>
if (_horizontalScrollbar != null) // && _verticalScrollbar != null)
/*if (_realTimeUpdate)
_horizontalScrollbar = new C1.Win.Chart.Interaction.AxisScrollbar(_fChart.AxisX);
_horizontalScrollbar.LowerValue = _horizontalScrollbar.UpperValue - 20;
_realTimeUpdate = false;
return;
// 20211102 : Manuel ha chiesto che la barra fosse completa per tutti i grafici (l'utente sceglie lo zoom non noi)
/*if (_AvgTypeSelected.Name == "5sec-ist")
//_horizontalScrollbar.LowerValue = _horizontalScrollbar.UpperValue - 20;
_horizontalScrollbar.LowerValue = _horizontalScrollbar.UpperValue/4; // prima era -20 ora ho upper/8 => 1 h
else
_horizontalScrollbar.UpperValue = _horizontalScrollbar.LowerValue + 20;
//_verticalScrollbar = new C1.Win.Chart.Interaction.AxisScrollbar(_fChart.Series[1].AxisY);
_firstPlot = false;
pnlGraph.Visible = true;
catch (Exception ex)
ctrlLogger.Error(System.Reflection.MethodBase.GetCurrentMethod().DeclaringType);
ctrlLogger.Error(ex.Message + "\n" + ex.StackTrace);
exitResult = false;
System.Windows.Forms.Cursor.Current = System.Windows.Forms.Cursors.Default;
return exitResult;
The data are now correctly proportioned, but the values on the axes are not correct .
It seems that these two instructions (BOLD) conflict:
AxisY = new Axis
Style =
