FlexChart: Plot reference lines
Posted by: hdle on 12 November 2024, 2:19 pm EST
    Posted 12 November 2024, 2:19 pm EST - Updated 12 November 2024, 2:24 pm EST
    Hi all,
    I am trying to add some reference lines to a plot to show reference level on y axis (and maybe X). I’ve tried using LineMarker, but could not place it on the Y data value correctly using HorizontalPosition.
    I tried annotation and that partially work. The line works. The label only shows if the line is short enough to just fit the current view. But if I make it long enough that you have to scroll horizontally, then the content text does not show. Is there a way to make it show always center, left, or right of the line in view? attached is the example of annotation line.
    Hai
  • Posted 13 November 2024, 8:27 am EST
    Hello Hai,
    We can achieve this scenario using the relative Line Annotation. However, we noticed the line is not rendered properly (the alignment is off by some factor).
    We have forwarded your use case to the development team to get their insights. Rest assured, we’ll get back to you once we have more information. [Internal tracking ID: C1WIN-33316]
    Uttkarsh.
  • Posted 25 November 2024, 6:34 am EST
    Hello Hai,
    As per the team, for this requirement, you can draw lines manually after the chart has been rendered. Please refer to the attached sample for the implementation. (see FlexChart_AnnotationLine.zip)
    Uttkarsh.
  • Posted 25 November 2024, 11:28 am EST
    Uttkarsh,
    That works!!
    Thanks!
    Hai
