FlexChart's BackgroundImage Issue
Posted by: fabio.lavitola on 21 August 2022, 4:36 am EST
    Posted 21 August 2022, 4:36 am EST
    with Legacy C1Chart (C1.Win.C1Chart.C1Chart) I was able to show a background Image to the Chart until I start populate it:
    C1_Chart_Test.BackgroundImage = Image.FromFile(…)
    After that I can see the Image in the background.
    With FlexChart, the same method does not shows any Image…
    I also didn0’t find anything in any sample you provided.
    What Am I doing wrong ?
  • Posted 21 August 2022, 4:49 am EST
    P.S. “RenderMode” property is set to “DirectX”; the default method works
  • Posted 22 August 2022, 3:36 am EST
    Hi fabio,
    Thanks for reporting this issue. We have replicated this issue at our end. This seems like a bug. So, that we have escalated it to the development team. We will inform you whenever we get any update on this. [Internal Tracking Id - C1CHART-2115]
    However, You can do a workaround for the same, by handling rendering event of FlexChart as:
    private void FlexChart_Rendering(object sender, RenderEventArgs e)
        var image = Image.FromFile("../../grapecity.png");
        e.Engine.DrawImage(image, 0, 0, flexChart.PlotRect.Width, flexChart.PlotRect.Height);
    Please refer the attached sample for the same : FlexChartBackgroudImage.zip
    Nitin.
  • Posted 22 August 2022, 3:50 am EST
    Hi NItin,
    atm I’ll change the rendermode via code just before populating with series, waiting for the final patch.THanks
    Fabio La Vitola
  • Posted 5 February 2023, 6:11 am EST
    Bug has been solved, thanks !
