FlexCharts on FlexReports
Posted by: connellyj on 2 May 2018, 11:07 am EST
    Posted 2 May 2018, 11:07 am EST
    I a report that was working in C1Reports. I pulled it into FlexReports and it behaves differently. I have a parent child relationship in my datasource. I want to print the data and present the grouped data in a line chart below the data. The data groups properly. But the Chart after each grouped set is a graph of all the data not the grouped data. I have the chart in the GroupFooter.
    How dow I tell the Chart to use the Group data? I see no filter property. I did set Y1Expression to my filter request but it had no effect.
  • Posted 3 May 2018, 1:24 am EST
    We tried to convert a C1Report with grouping based chart to a FlexReport and it turned out to be correct (see “ChartInGroupFooter.zip”). The only difference is that the chart is a Legacy ChartField rather than a FlexChart.
    However, even on using a FlexChart, we can add grouping based data to the same. For this, set XExpression and YExpression properties under Series along with the XLabelExpression property. A demo report showing the same is attached (“Products_ChartGrouping.zip”).
    The reports are bound to C1Nwind.mdb shipped with the product.
    Let us know if you need further assistance.
    ChartInGroupFooter.zipProducts_ChartGrouping.zip
  • Posted 3 May 2018, 7:14 am EST
    Thanks!
  • Posted 1 November 2018, 12:30 pm EST
    This did not actually help. I still get all the data in the chart in each group footer.
    Do I need to change the datasource? It is not working with the group subset of data.
  • Posted 2 November 2018, 5:50 am EST
    Can you please modify the previously attached report and share it back with the issue?
    This will help me understand where the issue exactly occurs and thus, I will be able to assist you in the right direction.
