Flexgrid column filter
Posted by: Ranba790 on 18 October 2018, 2:55 am EST
    Posted 18 October 2018, 2:55 am EST
    Hi
    Using the column filter on multiple columns create an AND condition between the column. The row will show if all the filters conditions are true.
    Is there a way to create a multicolumn filter with an OR condition.
    For example a grid with 2 columns and values ranging from 1 to 100.
    I would like to show rows that are over 80 in any of the columns.
  • Posted 18 October 2018, 5:15 am EST
    Column filters are used on a single column so it’s not possible to apply a filter which can check grid values from multiple columns.
    You would need to filter the values manually and hide the rows. Here’s an example:
    for (int row = _flex.Rows.Fixed; row < _flex.Rows.Count; ++row)
        bool rowVisibility = false;
        foreach (int col in filterColIndices)
            if (Convert.ToInt32(_flex[row, col]) > parameter)
                rowVisibility = true;
                break;
        _flex.Rows[row].Visible = rowVisibility;
    Please also find the attached sample where rows are filtered using OR condition.
    Jitender
    MultiColumnORFilter.zip
