Posted 9 August 2018, 11:55 am EST
I want to allow the user to drop files on my flexgrid. The flexgrid has only one visible column, the other columns are invisible. Currently the grid is databound but I could change that if necessary.
When the user drops the files (dragged from the explorer), I want to validate the files (only certain extensions are possible). This I have seen in the “DragDrop” example.
(drag enter event)
When the files are ok and the user drops them, I want to add a (generated from me) name in the only visible column, copy the file to another folder and only if this works, I want to write the absolute path of the file in a hidden column. All this should work for 1 or more files.
- How can I avoid that the c1flexgrid writes the path in the dropped cell?
- I want the user to able to drop the files somewhere in the grid. The new (from me generated) grid lines will always be at the end of the grid (new lines). No overwriting of existing cells.
Please help me somehow. Thank you.
