FlexGrid icon in column header
Posted by: fsegui on 27 November 2021, 5:32 pm EST
    Posted 27 November 2021, 5:32 pm EST
    I’m using C1FlexGrid binded to a datasource.
    I’m defining the columns prior to binding the datasource to personalize the headers (captions and other things).
    For some columns, I want to also add an icon in the header. How can I achieve that ?
    Florent
  • Posted 28 November 2021, 11:55 pm EST
    Hi Florent,
    You can set the icons in the column headers using the SetCellImage method of the C1FlexGrid. Kindly refer to the attached sample showing the same.
    Please let us know if you need any other information.
    Avnish
    IconColumnHeaders_C1FlexGrid.zip
  • Posted 29 November 2021, 6:01 am EST
    Hi Avnish,
    Thanks a lot, works like a charm.
    Another question: is it possible to define a tooltip for a cell directly?
    Best regards,
    Florent
  • Posted 30 November 2021, 1:39 am EST
    Hi Florent,
    If you want to display tooltips for the cells whose contents
    are partially hidden, you can do so by setting the ShowCellLabels property of the C1FlexGrid to true.
    If you want to show your custom tooltip, you can use the MouseMove event of the C1FlexGrid to set the tooltip according to the cell with the current mouse pointer.
    CellTooltip_C1FlexGrid.zip
    Avnish
  • Posted 30 November 2021, 6:03 am EST
    Hi Avnish,
    Thanks for the sample. It suits my needs.
    Florent
