FlexGrid in bound mode not refreshing
Posted by: Ranba790 on 1 July 2019, 10:07 am EST
    Posted 1 July 2019, 10:07 am EST
    Hi
    I have a flexgrid bound to a generic list of a class
    Dim DT As New List(Of clsAFE)
    gridData.DataSource = DT
    The grid display doesn’t update unless I call gridData.Refresh
    The DT is updated on different threads but only data, Item are not added or deleted.
    Any idea why the grid is not updating.
    Should I use Refresh or I need to use something else to cause the grid to display the new data after I have updated the data source data.
  • Posted 2 July 2019, 7:24 am EST
    I will suggest you to use a BindingList instead of List as your DataSource.List does not fire events when its collection changes.The reason is List<> implements IList interface that does not provide any events for value change whereas BindingList<> implements IBindingList interface that does expose ‘ListChanged’ for changes.
    You need to use Refresh() method each time whenever you made changes in the list but if you don’t want to call Refresh(), you just need to implement INotifyPropertyChanged for Class, BindingList automatically subscribes to property changes for each Class in the collection and lets the view know about the change.
    Code snippet is given below : ```
    Class Person
    Implements INotifyPropertyChanged
    Public Event PropertyChanged As PropertyChangedEventHandler
    Private Event INotifyPropertyChanged_PropertyChanged As PropertyChangedEventHandler Implements INotifyPropertyChanged.PropertyChanged
    Private _FirstName As String
    Private _LastName As String
    Private _Age As Integer
    Public Sub New(ByVal FirstName As String, ByVal LastName As String, ByVal Age As Integer)
    Me._FirstName = FirstName
    Me._LastName = LastName
    Me._Age = Age
    End Sub
    Public Property FirstName As String
    Get
    Return _FirstName
    End Get
    Set(ByVal value As String)
    If _FirstName <> value Then
    _FirstName = value
    OnPropertyChanged(“FirstName”)
    End If
    End Set
    End Property
    Public Property LastName As String
    Get
    Return _LastName
    End Get
    If _LastName <> value Then
    _LastName = value
    OnPropertyChanged(“LastName”)
    End If
    End Set
    End Property
    Public Property Age As Integer
    Get
    Return _Age
    End Get
    Set(ByVal value As Integer)
    If _Age <> value Then
    _Age = value
    OnPropertyChanged(“Age”)
    End If
    End Set
    End Property
    Overridable Sub OnPropertyChanged(ByVal [property] As String)
    RaiseEvent INotifyPropertyChanged_PropertyChanged(Me, New PropertyChangedEventArgs([property]))
    End Sub
    End Class
    Please refer to the attached sample where I have implemented the same.
    Thanks and Regards,
    [zip filename="UpdateBoundFlexGridDemo.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-ea1f35b2-e315-45e4-afe5-b1ea1e5ace46.zip[/zip]
