FlexGrid isn't working in the DEBUG mode
Posted by: sarthakgupta on 15 April 2020, 5:42 am EST
    Posted 15 April 2020, 5:42 am EST
    While using flexgrid in one of my applications. It isn’t working in the debug mode. But when i build the same application and run the .exe file of my application it works.
    Usage of flexgrid in my application
    I have created a grid in the windows form which has 4 rows to select from.
    As it is not working in the Debug mode. I am not able to Debug my code and hence hindering my work.
  • Posted 16 April 2020, 6:01 am EST - Updated 3 October 2022, 11:55 pm EST
    Hi Sarthak,
    It is very strange and we never came across this kind of issue before.
    We have created a demo application showing the same please have a look into the sample and the GIF attached and let us know if you are doing something else and modify the sample accordingly.
    FlexGridDebugDemo.zip
  • Posted 21 April 2020, 9:08 am EST - Updated 3 October 2022, 11:55 pm EST
    Hi Prabhat,
    Thank you for the response.
    Yes, This is bit similar to this Demo.
    I am adding screenshots for better explanation.
    This one is when i run the code in visual studio in debug mode
    This is when i run the .exe file of the same code after building the code succesfully.
    How can i resolve the issue. Please help
    Sarthak Gupta
  • Posted 22 April 2020, 5:05 am EST
    Hi Sarthak,
    We understand your concern.
    But it is not possible to investigate this with the given screenshots.
    In order to assist you accordingly we need the following information from your side:
    1: Are you facing the same issue with our given sample?
    2: If not then please modify the sample accordingly replicating the issue.
    3: Please share your environment details.
  • Posted 14 May 2020, 5:45 am EST
    Hi Prabhat,
    So, when i extracted the sample you provided and tried to build the application, it threw an error,
    Unable to resolve type ‘C1.Win.C1FlexGrid.C1FlexGrid, C1.Win.C1FlexGrid.4’ FlexGridDebugDemo in licenses.licx
    then i replaced the details in .licx file with the version of flexgrid i had i.e. C1.Win.C1FlexGrid.C1FlexGrid, C1.Win.C1FlexGrid.4.5.2,
    and changed the reference of flexgrid.dll in the application which i had.
    the demo application started to work fine.
    and suddenly when i checked my application. it also started to work fine. But suddenly one day when i restarted my PC , it stopped working in my application again.
    now i don’t know what helped to fix it earlier and why it broke again.
    Please help me with it.
    Sarthak Gupta
  • Posted 15 May 2020, 3:47 am EST
    Hi Sarthak,
    It is very strange and as I said earlier that we never came across this kind of issue before so we need your environment details to further investigate this.
    Note: This issue can be related to the visual studio so you can try it by cleaing the cache of VS or by updating the VS version.
