FlexGrid - Retrieve DisplayMember rather than ValueMember from Drop Down
Posted by: mwebster on 5 March 2019, 2:39 pm EST
    Posted 5 March 2019, 2:39 pm EST
    I am working with the FlexGrid control and I have several columns that I have added drop down lists to via code using the “DataMap” method. It works just fine.
    My issue is this. In one example, the drop down list contains a list of part numbers (the display member) and the underlying value member is the corresponding record ID. I have no problem retrieving the PartID value using code similar to:
    PartID = fgQuoteDetails.Rows(x).Item(“PartID”)
    In some instances, I need to get the display member though rather than the value member for that drop down list. I am not sure how to get that. Any suggestions?
    Mike
  • Posted 6 March 2019, 1:34 am EST
    Hi Mike,
    You just need to use the grid’s method GetDataDisplay to retrieve the corresponding display member. Code snippet is given below:
    Dim name As String = C1FlexGrid1.GetDataDisplay(rowIndex, colIndex)
    Documentation link: https://help.grapecity.com/componentone/NetHelp/c1flexgrid/webframe.html#C1.Win.C1FlexGrid.4~C1.Win.C1FlexGrid.C1FlexGridBase~GetDataDisplay.html
    Please refer the attached sample which demonstrates how to retrieve Display Member as soon as a cell is edited in the corresponding column. You can use the same approach in your scenario.
    Pragati
    DisplayDataMap.zip
  • Posted 6 March 2019, 8:56 am EST
    Thank-you!
    Mike
