FlexGrid Row Caption Problem
Posted by: moridi on 17 August 2018, 2:33 pm EST
  • Posted 17 August 2018, 2:33 pm EST
    I don’t know how i can assign a field of datatable as row caption.
    now after set Datasource do like this.
     for (int i = 0; i < Rows.Count; i++)
                    if (Rows[i].DataSource != null)
                        Rows[i].Caption = ((DataRowView)Rows[i].DataSource).Row.ItemArray[1].ToString();
    I need show a field value as row caption, this method is a bit slow.
    I forgot to day I need Merge the caption too.
  • Posted 20 August 2018, 1:51 am EST
    There is no method to directly set Row Caption for the Grid. The code you’ve posted is currently the best way to do this.
    Regards.
  • Posted 20 August 2018, 2:05 pm EST
    Thanks but it is slow when we have a lot of row in datasource
    I show the 50,000 record in grid it’s have good speed but for caption make 3-4 times more.
    Regards.
  • Posted 21 August 2018, 11:38 pm EST
    You can set your DataTable as DataSource for the grid, and set the style of the column having Row Caption field to Fixed style to make it look like a Fixed column.
    You can refer to the attached sample which makes column “OrderID” as fixed column and uses merging on that column.
    Regards.
    RowCaptionFromDataSource.zip
