FlexGrid sort
Posted by: Ranba790 on 3 September 2018, 4:56 am EST
  • Posted 3 September 2018, 4:56 am EST
    Hi.
    For some strange reason, the sort feature when clicking the column header is not working.
    I have :
    .AllowSorting = C1.Win.C1FlexGrid.AllowSortingEnum.SingleColumn
    and
    Col(i).AlowSort = True.
    The grid is in a bound mode to a data table, The AllowFilter is also set to true and working properly.
    Any idea what am I missing.
  • Posted 3 September 2018, 6:12 am EST
    I could not replicate your issue at my end. I’ve attached the sample I used to replicate the issue.
    Please see if you still have the same problem with this sample. If the sample works correctly then please modify it so I can further investigate the problem.
    Regards.
    FlexGridSortVB.zip
  • Posted 6 September 2018, 5:34 am EST
    Hi
    I am unable to simulate it, I took the example and try to make it as close as possible to my project but it works ok in the sample, I think it might be related somehow to the data feeding the grid, It used to work ok before I switched to bound mode(the table used to be populated in an unbound mode), if you have any idea how I can troubleshoot this issue it will be much appreciated
    thanks
  • Posted 7 September 2018, 2:21 am EST
    The only reasons for sorting to not work can be:
    1. Using bound and unbound columns, in which case sorting does not work for unbound column.
    2. Using a List as Data Source of FlexGrid. See this link to solve this problem:
      https://www.grapecity.com/en/blogs/sort-c1flexgrid-bound-to-a-bindinglist
    If you’re using a DataTable as DataSource, can you please send a small sample replicating the issue so I can investigate this further?
