Flexpivot Localization
Posted by: ahmdsalh on 1 November 2017, 4:39 pm EST
    Posted 1 November 2017, 4:39 pm EST
    I’m new to using c1 components for winforms (VB.Net)
    How can I change the language of the titles, tooltips and other text of a flexpivot control.
    I need it to support Arabic and Portuguese.
    I seached the documentation and found nothing.
    Highly appreciate your support.
    Thanks in advance
  • Posted 2 November 2017, 4:14 am EST
    Hi Ahmed!
    You can add the given code snippet to your application,
    1. For Arabic:
    System.Threading.Thread.CurrentThread.CurrentCulture = New System.Globalization.CultureInfo("ar-EG")
    System.Threading.Thread.CurrentThread.CurrentUICulture = New System.Globalization.CultureInfo("ar-EG")
    1. For Portuguese:
    System.Threading.Thread.CurrentThread.CurrentCulture = New System.Globalization.CultureInfo("pt-PT")
    System.Threading.Thread.CurrentThread.CurrentUICulture = New System.Globalization.CultureInfo("pt-PT")
    Attached is the sample that demonstrates the same for Arabic.
    Meenakshi
    Prj_FlexPivotPage_VB.zip
  • Posted 2 November 2017, 8:02 am EST
    Nice. Thank you.
    for “de-de”
  • Posted 3 November 2017, 12:43 am EST
    Hi Andreas!
    Sorry but I could not get your point here. If there is any localization issue w.r.t. this culture, you can let me know the same.
    Meenakshi
  • Posted 14 November 2017, 7:32 am EST
    Hi!
    Is it possible for you to help us with Arabic translation in FlexPivotPage, for its improvement?
    I am attaching resources file “resx.zip” (translation of only value fields is required), along with the menu popup image “Img_MenuPopup.png” (menu options need to be translated).
    Meenakshi
    resx.zip
  • Posted 9 December 2017, 10:25 am EST
    Hi, at the time of the post I just wanted to say thank you and that it s nicely working for German too. In the meantime I did some examples for customers and noticed some errors in the translations which I will send you within this thread in detail as soon as work allows …
    Thank you and Regards.
  • Posted 11 December 2017, 2:17 am EST
    Hi!
    Oh! I am glad that it worked for you too.
    And no issues Andreas. Update me once you are done, so that I can take appropriate actions in resolving the translation errors.
    Meenakshi
  • Posted 21 December 2017, 9:16 pm EST
    Yes sure i can help in Arabic translation.
    example: for the popup menu:
    Copy = نسخ
    Show Details = اظهر التفاصيل
    Field Settings = إعدادات الحقل
  • Posted 22 December 2017, 12:26 am EST
    Hi!
    Thank you for this.
    However, there is a resources file also that needs some translation. I am attaching that file “resx.zip” (in which translation of only value fields is required) to this post also. Kindly let me know once this is completed.
    resx.zip
    Best regards,
    Meenakshi
  • Posted 22 December 2017, 5:22 pm EST
    Ok. I will let you know … I will take a look at it now
    Also, i have another question regarding localization.
    How can i convert flexreportviewer to arabic as well? the culture change doesn’t work
  • Posted 26 December 2017, 2:54 am EST
    Hope this helps.
    Meenakshi
