FlexReport change datasource after template is made
Posted by: jacobturley on 12 October 2017, 12:18 pm EST
    Posted 12 October 2017, 12:18 pm EST
    Hey all! So I am new and evaluating this, and trying to figure this out. Essentially, we want a “fancy print” of the data that we are displaying in a grid. Is there a way for me, through the gui, able to design the report(i.e. they layout with images etc.) and then just add fields to the detail section dynamically? Sorry I am new. It looks like it is possible, I just don’t know how to EDIT and add fields to an existing template.
  • Posted 13 October 2017, 4:40 am EST
    Using the Data group on the Home Tab of the C1FlexReportDesigner, you can change the Data Source any time after you have fixed a report’s style/ template. Refer the below documentation link that shows the group in the Design mode.
    http://helpcentral.componentone.com/nethelp/FlexReport/DesignMode.html
    Also, Data Source can be changed at run-time for any report using the below mentioned code snippet:
    c1FlexReport1.DataSource.RecordSourceType = RecordSourceType.Auto;
    string dsPath=Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments).ToString();
    c1FlexReport1.DataSource.ConnectionString = @"Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" + dsPath +@"\ComponentOne Samples\Common
    \C1NWind.mdb";
    c1FlexReport1.DataSource.RecordSource = "Employees";
    You can add fields like images, charts, shapes, etc in a report using the FlexReportDesigner using the Insert tab. You can learn more about inserting each field from the below documentation link:
    http://helpcentral.componentone.com/nethelp/FlexReport/AddingFlexReportFields.html
    For images, you might want to follow the steps mentioned here:
    http://helpcentral.componentone.com/nethelp/FlexReport/ImageField.html
    Next, you can add fields to the Detail section dynamically using the below code snippet:
    // create the Detail section
               s = c1FlexReport1.Sections[SectionTypeEnum.Detail];
               s.Height = 330;
               s.Visible = true;
               TextField textField = new TextField();
               textField.Name = "FldID";
               textField.Text.Expression = "EmployeeID";
               textField.Left = 0;
               textField.Top = 0;
               textField.Width = 400;
               textField.Height = 300;
               c1FlexReport1.Sections.Detail.Fields.Add(textField);
    Here, a TextField is inserted.
    Let us know if you wish to display the grid as an image or simply a grid-like layout which can be obtained using the borders of the fields and sections and ShapeFields.
    Hope this helps.
