FlexReport - Custom html field - CanGrow doesn't work
Posted by: mary431982 on 14 November 2019, 5:15 am EST
  • Posted 14 November 2019, 5:15 am EST
    I am sending you example of a custom html field with a lot of text which is not shown even if CanGrow is set to true??!!
    Can you see what is the problem?
    Thanx.
  • Posted 14 November 2019, 5:17 am EST
  • Posted 15 November 2019, 1:11 am EST
    You seem to be adding plain text to a SuperLabel. Note that the field is used to insert HTML text in reports.
    http://help.grapecity.com/componentone/NetHelp/FlexReport/webframe.html#SuperLabelCustomField.html
    Adding your text to a TextField and setting the AutoHeight property to CanGrow makes the field grow accordingly. Also, CanGrow for the SuperLabel works well when it has HTML content in it. This has been shown in “Report 2” of the attached report file.
    test_modified.zip
  • Posted 15 November 2019, 5:48 am EST
    Hello, I do use html with super label and the CanGrow is not working…
    Sorry - in the report I sent you I tried to simplify everything and I used plain text by mistake…
    I modified your Report2 and CanGrow is not working.
  • Posted 15 November 2019, 5:50 am EST
  • Posted 18 November 2019, 2:13 am EST
    Thank you for the file. I could observe the problem as well and have escalated the same to the concerned team [Internal Tracking ID: 407598].
    Will get back to you once I receive any information.
    Regards.
  • Posted 18 November 2019, 5:04 am EST
    Thank you, I hope that will be soon. Regards
  • Posted 25 December 2019, 12:11 pm EST
    Hello, any news on this?
  • Posted 26 December 2019, 12:16 am EST
    The issue is fixed internally. I will get back to you when the build containing the fix is released.
  • Posted 26 December 2019, 4:21 am EST
    The internal build has been shared over the SupportOne case: https://supportone.componentone.com/home/casedetail/414813.
    Please log in using the same credentials you use here on the grapecity website.
  • Posted 31 December 2019, 10:40 am EST
    Hello, I tried to use it but I realized that we use C1.web.api.report and we need appropriate DLLs which I cannot find in your example. Can you send me appropriate version? When can we expect that improvement in the new release?
    Thanx.
  • Posted 3 January 2020, 4:57 am EST
    Hi Mary,
    We are sorry for the inconvenience since the issue has been originally reported for the WinForm, hence the issue was not in acknowledgment of the WebApi team.
    We have acknowledged them about that and we will let you know as we hear something on this.
    Manish Gupta
  • Posted 28 October 2021, 7:59 pm EST
    I downloaded the latest available Nuget Package (version C1.FlexReport.4.5.20192.382) and still see the same problem. The SuperLabel.Text value has the HTML tags but not auto-growing. Any ideas?
    I noticed the following:
    1. I can workaround it by appending “
      ” to the end of the html formatted text.
    2. If I have one line of text plus 3 bullets underneath ( key was used), it auto-grows and shows the text correctly in the report
    3. For the example in #2 above, if the line of text grows to two lines, only 2 bullets underneath will be shown. The 3rd bullet is gone missing. (updated: OK… doing the same workaround in #1 above resolved it.)
  • Posted 29 October 2021, 6:19 am EST
    The issue was fixed in the 2019v3 release. The version you are using is the 2019v2 release. Please download the latest 2021v2 [version 4.5.20212.520] release and let us know if the issue persists.
    Nuget Link: https://www.nuget.org/packages/C1.Win.FlexReport/4.5.20212.520
    Avnish
  • Posted 1 November 2021, 3:31 pm EST
    The package you recommended (4.5.20212.520) has C1.Win.C1SuperTooltip.4.5.2.dll missing that I need it for SuperLabel
  • Posted 2 November 2021, 10:33 pm EST
    You can install the C1SuperToolTip using the C1SuperToolTip NuGet package, https://www.nuget.org/packages/C1.Win.C1SuperTooltip/.
    Avnish
  • Posted 3 November 2021, 7:40 pm EST
    Tried with packages 4.5.20212.520 and it did fix the problem of AutoHeight CanGrow.
    Thanks!
