Flexreport - Display picture from filename stored in database
Posted by: storerware72 on 1 March 2025, 10:53 am EST
    Posted 1 March 2025, 10:53 am EST
    Sorry but have gone brain dead! VS2022, C#, Flexreport Designer 8. Just transitioned from SAP Crystal.
    Need to display picture on Flexreport that is based upon a filename stored in SQL Server. Have read/followed the documentation but no luck. No problems with displaying info from other fields in the same record. Just the picture.
    Got to be something I have missed.
    Any thoughts would be appreciated.
    Thanks in advance!
  • Posted 3 March 2025, 5:04 am EST - Updated 3 March 2025, 5:09 am EST
    You just need to drag-drop a Picture field to the report and set its Picture property with the data field having the filename.
    Please refer to the attached sample report for implementation. (see SampleReport.zip)
    Uttkarsh.
  • Posted 3 March 2025, 7:24 pm EST
    Many thanks! Your report works perfectly. And it helped me further isolate the issue.
    Something more is at work as Flexreport will not display JPG files.
    Your example of PNG files works great but not with JPG. However the ones I am required to utilize are JPG.
    And Flexreport will not display any JPG files.
    Docs indicate it will.
    Gonna have to dig around a bit to find out why.
    Thanks again!
  • Posted 4 March 2025, 4:57 am EST
    We’re able to observe the behavior as well and have shared the observations with the development team for further insights. [Internal tracking ID: C1WIN-33749]
    Rest assured, we’ll update you once we have more information.
    Uttkarsh.
  • Posted 4 March 2025, 9:54 am EST
    Thanks for the update.
    An aside, will not display TIF or Bitmap either.
    Look forward to the fix!
  • Posted 5 March 2025, 5:10 am EST
    Thanks for the information.
    As per the development team, the reported issue is a bug. Rest assured, we’ll update you once the issue has been fixed. [Bug Tracking ID: C1WIN-33751]
    Uttkarsh.
  • Posted 5 March 2025, 7:45 am EST
    Thanks!
  • Posted 6 July 2025, 6:15 am EST
    Hello
    As per the development team, the issue has been fixed in the 2025v1 release.
    Please install the latest 2025v1 version to resolve the issue.
    Download the latest ComponentOneControlPanel from https://developer.mescius.com/componentone/download.
    Uttkarsh.
  • Posted 6 July 2025, 8:09 am EST
    Email excerpt sent to you on June 13…
    “Unfortunately my License expired 2024 and cannot utilize 2025v1. No budget money to renew so I am stuck with the current version. Will have to find a “work around” to the problem that will fit with our computing environment.”
    The work-around is to take the selected JPG file and make a temp copy on the local drive. Then convert it to PNG. Print report. Delete the temp file copy after reporting.
    Storer
