FlexReport Export to PDF RTL support
Posted by: Guy on 5 May 2018, 9:26 am EST
    Posted 5 May 2018, 9:26 am EST
    using the latest build of FlexReport (4.0.20181.303) when we try to export the report to PDF all RightToLeft=True fields ending with punctuation marks (colon, semi-colon, period, etc’) the punctuation marks appear in the wrong order.
    Viewing the report is just fine, exporting to RTF is OK, printing is fine…
    Attached are 3 files:
    1. The Report itself (Report.xml)
    2. The PDF Export outcome (C1-PDF.pdf)
    3. The PDF - Print output - Print to ‘Microsoft Print to PDF’ (MS-PDF.pdf)
    Are we setting it wrong? is it a BUG?
    Guy
  • Posted 5 May 2018, 9:29 am EST
    Here are the files…
    FlexReport2Pdf.zip
  • Posted 7 May 2018, 12:24 am EST
    Thanks for sharing the details and the files. We could observe the issue at our end and have escalated [Internal Tracking ID: 320720] it to the concerned team.
    We will get back to you once we hear from them.
  • Posted 24 May 2018, 10:44 am EST
    Hi Esha,
    Any News? Updates?
    I must export the report to PDF correctly. I Have an XPS-2-PDF converter but rendering a report to XPS is not possible (or so i’ve been told by your support…)
    Awaiting your reply,
    Guy
  • Posted 24 May 2018, 11:09 pm EST
    Hello Guy,
    As per the team, the issue will be fixed in the upcoming 18v2 builds.
    We will notify you once the build containing the fix is released.
  • Posted 13 June 2018, 4:41 pm EST
    Hi Esha,
    What is the expected release date?
    Also, as the issue is pressing, could you provide me with a beta/pre-release fixed version?
    Thank you,
    Guy.
  • Posted 15 June 2018, 1:01 am EST
    Hello Guy,
    Please refer the SupportOne ticket [https://supportone.componentone.com/home/casedetail/327515] addressing your request.
    Hope it helps.
  • Posted 27 June 2018, 1:52 am EST
    Hi Esha,
    Thank you for providing the files. However the issue is PARTIALLY FIXED…
    • RightToLeft=True fields ending with punctuation marks (colon, semi-colon, period, etc’) the punctuation marks appear OK.
    • RightToLeft=True fields starting with numbers OR punctuation marks (colon, semi-colon, period, parentheses , brackets , etc’) the entire line appear in the wrong order.
    Attached are 3 files (in the ZIP):
    1. The Report itself (Report1.xml)
    2. The PDF Export outcome (Report1.pdf)
    3. The XPS Export outcome, Via FlexViewer (Report1.XPS)
    4. The BUG (Report1-BUG.png)
    5. How it should be (Report1-OK.png)
    Please fix it in the same 2018v2 build…
    Guy.
    FlexReport2Pdf1.zip
  • Posted 28 June 2018, 4:58 am EST
    Thank you for sharing the files, Guy.
    I have forwarded the issue to the developers on priority. Will let you know once there is any information from them.
    ~Pragati
  • Posted 5 July 2018, 2:00 am EST
    Hi Guy,
    We are happy to let you know that issues you reported have been fixed now.
    In order to verify the same, please upgrade to the latest version available using C1Live (C:\Program Files (x86)\ComponentOne\C1Live) or use the following link to download the new build version: http://prerelease.componentone.com/dotnet40/C1WinForms/2018-T2/C1WinForms.4_4.0.20182.314.zip
    Ruchir
  • Posted 19 July 2018, 9:27 am EST
    Hi Ruchir,
    We’re testing build 4.0.20182.314 and it seems that the issue was fixed however it “bugged” a different issue.
    Now all fields containing only numbers & punctuation marks - all punctuation marks are printed at the end of the number…
    Causing dates to print 01072018// instead of 01/07/2018, or 1234569-- instead of 123-456-9
    1. The Report itself (Report2.xml)
    2. The PDF Export outcome (Report2.pdf)
    3. The XPS Export outcome, Via FlexViewer (Report2.XPS)
    4. The BUG (Report2-BUG.png)
    5. How it should be (Report2-OK.png)
    Please fix it…
    Guy.
    FlexReport2Pdf2.zip
  • Posted 20 July 2018, 2:48 am EST
    Hello Guy,
    Thanks for the files and the description of the issue.
    We could observe the issue at our end as well, and hence, have requested the development team to look into the same.
    Will get back to you once we hear from them.
  • Posted 29 July 2018, 2:03 am EST
    Hi Esha,
    Any news?
    We need this fix…
    Guy
  • Posted 30 July 2018, 2:05 am EST
    Hi Guy,
    I am in discussion with the development team over the same. Will get back to you once it is done.
  • Posted 1 August 2018, 1:54 am EST
    Hello Guy,
    The issue has been fixed internally and is under QA as of now. We will let you know once it is complete.
  • Posted 12 August 2018, 11:44 am EST
    Hi Esha,
    Any updates?
    Guy.
  • Posted 14 August 2018, 5:20 am EST
    Hello Guy,
    I have responded to your concern on SupportOne.
    Please refer the same.
