FlexReport - Merge same value cells
Posted by: mary431982 on 14 November 2019, 5:01 am EST
    Posted 14 November 2019, 5:01 am EST
    is it possible to merge cells with same value in FlexReport column in detail?
    Thanx
  • Posted 14 November 2019, 7:24 am EST
    Though direct merging is not possible, you can hide the duplicate values using script, as explained in the blog link below:
    https://www.grapecity.com/blogs/flexreport-tips-and-tricks#duplicatevalues
    Hope it helps.
  • Posted 15 November 2019, 5:45 am EST
    I used to use property HideDuplicates in C1 which also exists in FlexReport but its not working. Why I must use your script instead of property HideDuplicates?
    http://helpcentral.componentone.com/nethelp/FlexReport/C1.Win.FlexReport.4~C1.Win.FlexReport.Field~HideDuplicates.html
  • Posted 15 November 2019, 7:28 am EST
  • Posted 18 November 2019, 5:00 am EST
    This field that you refer to, is a Legacy Field. It is the field based on the Field class (as in C1Report), instead of the FieldBase class. However, I understand that the HideDuplicates property of this field should work as expected and hence, I have escalated this issue to the concerned team [Internal Tracking ID: 407641]. Will get back to you when I receive any update.
    Specifically FlexReport related TextFields do not have this property and for using them, scripts can used (as previously mentioned).
  • Posted 26 December 2019, 10:31 am EST
    Hello, did your team solved this? Regards
  • Posted 27 December 2019, 7:29 am EST
    I have requested the team for an update. Will get back to you once I receive any information.
    Regards.
  • Posted 3 January 2020, 1:21 am EST
    Just for our information, do you use C1.web.api.report here as well?
  • Posted 3 January 2020, 5:07 am EST
    :slight_smile: Yes.
  • Posted 6 January 2020, 5:49 am EST
    Thank you for the information.
    The issue will be fixed with 2020v1 release.
  • Posted 18 March 2020, 6:56 am EST
    I am glad to inform you that the issue has been fixed in the latest build (i.e. 2020v1). You can get it from here:
    http://prerelease.componentone.com/dotnet452/c1winform/2020-t1/C1WinForms-452_4.5.20201.416.zip
    Pragati
  • Posted 29 July 2020, 8:31 am EST
    Hello, I would like to use the script that you have mentioned here but I need to know how to use the script in a dynamically created report. I am building the report dynamically in code setting up the report header, page header, detail, and page footer. I need to know how to add script dynamically also so it can use the script when the report is built to omit duplicates.
  • Posted 30 July 2020, 5:00 am EST
    Hi Bernard,
    You can use the OnFormat or OnPrint property of the Section class of the FlexReport to write your script.
    The links for the same is given below:
    https://www.grapecity.com/componentone/docs/win/online-flexreport/C1.Win.FlexReport.4.5.2~C1.Win.FlexReport.Section~OnFormat.html
    https://www.grapecity.com/componentone/docs/win/online-flexreport/C1.Win.FlexReport.4.5.2~C1.Win.FlexReport.Section~OnPrint.html
    If you need any other help, please let me know.
  • Posted 31 July 2020, 8:08 am EST
    The URLs you provided respond with an Invalid URL message. And I did see the OnFormat property but didn’t know how to set this property. I need to know how I can add multiple lines of script so a full If condition can be interjected.
  • Posted 4 August 2020, 1:54 am EST
    Hi Bernard,
    Sorry for the invalid URLs.
    I have attached a demo sample which shows how you can write scripts via code at runtime, please take a look.
    You can also go through the following links which demonstrate the same:
    https://www.grapecity.com/componentone/docs/win/online-flexreport/HidingaSectionIfthereisNoData.html
    https://www.grapecity.com/componentone/docs/win/online-flexreport/ShowingorHidingaFieldDependingonaValue.html
    FlexReportRunTimeDemo.zip
  • Posted 4 August 2020, 9:20 am EST
    I tried a few options here and I can get the ForeColor of a field to change based on the values of fields in the Detail but I can seem to change the BackColor. I found a sample where someone is using a count and the mod function to check for every other line and set the background color but it won’t work. Can you tell me what I am doing wrong?
    Public LineColor As String = "cnt = cnt + 1" & vbCrLf & _
                                "If cnt Mod 2 = 0 Then" & vbCrLf & _
                                "  Detail.BackColor = RGB(211,211,211)" & vbCrLf & _
                                "Else" & vbCrLf & _
                                "  Detail.BackColor = vbWhite" & vbCrLf & _
                                "End If"
        ' Create the Detail section
        s = C1FlexReport1.Sections(SectionTypeEnum.Detail)
        s.Name = "Detail"
        s.Height = 500
        s.Visible = True
        s.AutoHeight = AutoSizeBehavior.GrowAndShrink
        s.Border = New Border(2, Color.Black, DashStyle.Solid)
        s.OnFormat = LineColor
  • Posted 5 August 2020, 4:22 am EST
    Hi Bernard,
    Please use the code snippet given below to do the same:
    c1FlexReport1.OnOpen = "_styleCtr = 0";
    c1FlexReport1.Sections.Detail.OnPrint = "detail.BackColor = iif(_styleCtr mod 2 = 0, rgb(211, 211, 211), vbWhite)_styleCtr = _styleCtr + 1";
  • Posted 5 August 2020, 9:10 am EST
    Okay, that works! Thanks!
