FlexReport - table - grow all field in a row
Posted by: mary431982 on 18 November 2019, 5:01 am EST
    Posted 18 November 2019, 5:01 am EST
    In detail section I have number of rows of fields that look like a table,if some of the fields grows - how can I make all the other fields from the same row grow too?test.zip
  • Posted 19 November 2019, 5:50 am EST
    I have modified your report to use CalculateSize method of the section and then set the height of Field1 and Field3, based on the rendered height of Field2. This is done in the Detail.OnFormat script, as follows:
    Detail.CalculateSize()
    Field1.Height= Field2.RenderHeight
    Field3.Height=Field2.RenderHeight
    test_modified.zip
  • Posted 19 November 2019, 8:52 am EST
    Ok, I get it, thank you,
    but how would it look like in general case?
    How would the code look like in the case of:
    • first - find the max height of all the fields in the detail
    • second - set that height to all the fields in the detail
    Thanx
  • Posted 20 November 2019, 1:41 am EST
    This would require manually comparing RenderHeight value for all the fields and then assigning the maximum height value to those fields.
    test_new.zip
  • Posted 20 November 2019, 4:49 am EST
    Thanx,
    Though, I was hoping for a more elegant solution, for example For loop for all N fields…I have more than 30 fields and I didn’t want to write few lines for all 30 fields…
    I wanted to use For loop or smth as elegant as that.
  • Posted 20 November 2019, 6:32 am EST
    Yes, this is possible as well. It’s another way of comparing field values using VB Script for the purpose:
    Dim maxheight=0
    For i=0 to 4
      For j=0 to 4
    If Report.Fields(i).RenderHeight > Report.Fields(j).RenderHeight  Then
    maxheight=Report.Fields(i).RenderHeight
    Else
    maxheight=Report.Fields(j).RenderHeight
    EndIf
      Next
    Next
    For i=0 to 4
    Report.Fields(i).Height=maxheight
    Next
    Regards.
  • Posted 20 November 2019, 8:06 am EST
    Ok, thank you very much. That is what I wanted!!! :slight_smile:
