Flexreport unbound mode report topposition problem
Posted by: sanjeeb.srjm on 5 January 2022, 1:46 am EST
  • Posted 5 January 2022, 1:46 am EST
    Dear Sir/Mam,
    for every page in unbound flexreport-
    top-position should start from suppose we have set it to 500
    but when it goes to 2nd page it expects first-page-height + toppos, why ?
    otherwise start printing from 1st-page again…
    or am i doing any wrong ?
    Please guide.
    Regards-
    Sanjeeb
  • Posted 5 January 2022, 1:52 am EST
    Also we have set Detail Section Height to 12000
    but Detail Section Height also expecting the same ?
  • Posted 6 January 2022, 5:49 am EST
    Hi Sanjeeb,
    FlexReports are section-based reports. A flex report or a .flxr file is divided into sections. You can open a report in the FlexReportDesigner app to view its sections. Every report consists of basic sections such as Report Header, Page Header, Group Header, Detail, Group Footer, Page Footer, Report Footer, and Sub-section.
    Each section has a different use and is rendered in a particular order. You can refer to the documentation at https://www.grapecity.com/componentone/docs/win/online-flexreport/SectionsofC1FlexReport.html for more information.
    Usually, when you create a FlexReport, the fields are added in each section and a layout is created. Then Report is bound to data and the details section gets generated based on that data. Now if a section extends beyond a page, a page break is added according to the settings.
    So when you are using the report in unbound mode and adding fields to a section you are just extending the section, that is why you need to add the heights and give a location corresponding to the very top.
    Then when the report is previewed, the page breaks will be added according to the setting you have for your report.
    I hope this helps.
    We would again like to suggest you use the FlexReports in bound mode as we suggested before in your previous cases, as it will be easier to manage and modify the fields and will give you better performance.
    Avnish
  • Posted 6 January 2022, 8:23 am EST
    Dear Sir,
    All types of report format is not being possible by Bound Mode.
    That’s why considering unbound mode.
    Please look into below problem and advise solution if any… please …
    https://www.grapecity.com/my-account/my-support/case/CAS-27463-S8Y3C4
    Regards-
    Sanjeeb
  • Posted 7 January 2022, 7:10 am EST
    Hi Sanjeeb,
    We request you to continue the discussion related to Case CAS-27463-S8Y3C4 on the case’s thread for better tracking and separation of issues.
    Regarding the case, we are waiting for the sample report that you mentioned that you will post soon. As soon as you share the sample report, our team will continue the thread and help you accordingly.
    Avnish
  • Posted 7 January 2022, 7:33 am EST
    Dear Avnish Sir,
    Extremely Sorry for inconvenience.
    Below link has sample project as well as image …
    https://www.grapecity.com/forums/winforms-edition/flexreport-bill-details-pr
    Regards-
    Sanjeeb
  • Posted 10 January 2022, 7:56 am EST
    Hi Sanjeeb,
    We have informed the assigned engineer of CAS-27463-S8Y3C4 about the sample. Please continue the thread there.
    Avnish
