FlexReport (WinForms) Set Tag value
Posted by: mwebster on 20 May 2021, 3:00 pm EST
    Posted 20 May 2021, 3:00 pm EST
    I am running into an odd issue with Flex Report. I am loading a report, setting its data source to a datatable, placing some text in the report.tag property and displaying the report in a flexviewer. This is the code I am using:
            C1FlexReport1.Load(RptPath, RptTitle)
            C1FlexReport1.Tag = RptTag
            C1FlexReport1.DataSource.Recordset = RptData
            C1FlexViewer1.DocumentSource = C1FlexReport1
    Everything works great except that the value that I place in the Tag property. I am trying to show that value in a field and it does not work. if I edit the report and stick a test value into the Tag property and run my report, it appears as expected but when I set the tag property using the above code, it does not work. Any suggestions?
  • Posted 21 May 2021, 2:58 am EST
    Hi Mike,
    Sorry, we do not face the issue at our end when updating the Tag value via Code.
    Please find the attached sample implementing the same.
  • Posted 21 May 2021, 2:59 am EST
  • Posted 21 May 2021, 6:42 am EST
    Sorry - figured it out. Was a dumb error on my part.
