Posted 1 November 2019, 3:06 am EST
Hi guys,
Is there any way to set Date format on Field to use CultureInfo from my app.
It seams as like always use CultureInfo from my computer settings.
Posted by: brezodejan on 1 November 2019, 3:06 am EST
Hi guys,
Posted 1 November 2019, 3:59 am EST
make this call before the report is generated:
System.Globalization.CultureInfo.CurrentCulture = new System.Globalization.CultureInfo("de-DE");
Hope this helps
Posted 1 November 2019, 10:11 am EST
I do that. Actually, I change formats in CurrentCulture for “en-US” and when I check it in debbuger in FlexReport.ActualCulture, everything is OK, but I don’t get formatted Date on generated Report
PS:
"System.Globalization.CultureInfo.CurrentCulture = new System.Globalization.CultureInfo("de-DE")"
``` doesn't work because of compiler error: [i]Property 'CurrentCulture' is 'ReadOnly'.[/i]
Posted 1 November 2019, 10:39 am EST
Seems you use .NET 4.5, where this property is readonly - I tested it with 4.6.
You might follow the suggestion from here:
https://docs.microsoft.com/en-us/dotnet/api/system.globalization.cultureinfo.currentculture?view=netframework-4.8
“To change the current culture, you assign the CultureInfo object that represents the new culture to the Thread.CurrentThread.CurrentCulture property”
Posted 1 November 2019, 12:16 pm EST
I know how to change the culture settings, and as I said before:
I change culture settings in the other way. I attached the picture with debugger settings and values I’ve already set. I show you on picture that the property ActualCulture has changed formats. But, the format on generated reports is like in System Culture settings.
I have to use .net framework 4.0
I don’t expect that the usage of this version of framework is problem or…?
Posted 2 November 2019, 10:35 am EST
I investigate and realized that the problem is more complex. You are right - everything is working if the date field is in main report.
But problem is if you have date field in a subreport.
I will attach the simple example and I hope that you will give me a way how to resolve the issue.WindowsFormsApp1.zip
Posted 4 November 2019, 2:24 am EST
You can set the culture of subreport explicitly like as follow:
this.c1FlexReport1.Culture = new System.Globalization.CultureInfo("en-US");
this.c1FlexReport1.Culture.DateTimeFormat.ShortDatePattern = "dd.MM.yyyy";
this.c1FlexReport1.Load("..\\..\\Report1.flxr", "New Report");
(this.c1FlexReport1.Sections["Detail"].Fields[1] as C1.Win.FlexReport.SubreportField).Subreport.Culture = new System.Globalization.CultureInfo("en-US");
(this.c1FlexReport1.Sections["Detail"].Fields[1] as C1.Win.FlexReport.SubreportField).Subreport.Culture.DateTimeFormat.ShortDatePattern = "dd.MM.yyyy";
this.c1FlexViewer1.DocumentSource = this.c1FlexReport1;
Hope it helps.
