Posted 15 May 2018, 5:57 am EST
Hi ALL
i use c1flexgrid.classic.4 version: 4.0.20173.286
set_RowHeight(-1, x) make the flexResizeBothUniform doesn’t work
look at the following example: flexResizeBothUniform.zip
thanks.
Posted by: samo3889 on 15 May 2018, 5:57 am EST
Hi ALL
thanks.
Posted 16 May 2018, 5:07 am EST
Hi Saleem!
It seems to be a bug, and I’m reporting this issue to the development team [Internal ID : 322297].
Meenakshi
Posted 22 May 2018, 10:28 am EST
can you please update me while it’s fixed
thanks.
Posted 24 May 2018, 12:05 am EST
Sure. Currently, this is with the concerned team. But you will be notified once it is resolved.
Posted 24 May 2018, 5:16 am EST
Sorry to mention that this is a limitation, currently.
Meenakshi
Posted 27 May 2018, 7:30 am EST
hi meenakshi
I need a solution please!!
Is there no temporary solution to offer me ?!
thanks
Posted 28 May 2018, 2:55 am EST
WorkAround Solution:
grid.AfterResizeRow += grid_AfterUserResize;
private void grid_AfterUserResize(object sender, EventArgs e) { if (Row != -1) { moFlex.RowHeightMax = moFlex.RowHeightMin = -1; moFlex.set_RowHeightEx(-1, moFlex.get_RowHeight(Row)); } } public static void set_RowHeightEx(this C1.Win.C1FlexGrid.Classic.C1FlexGridClassic instance,int Row, int RowHeight) { if(Row == -1) { instance.RowHeightMin = RowHeight; instance.RowHeightMax = RowHeight; } else { instance.set_RowHeight(Row, RowHeight); } }
thanks
Posted 28 May 2018, 4:43 am EST
I understand the criticality of the problem for you. We are actually trying to investigate it further in order to get a workaround. Will let you know once reach to a conclusion.
~Pragati
Posted 28 May 2018, 11:14 pm EST
I am glad to know that you were able to find a workaround for this problem.
Thanks for sharing it.
Marking this thread closed now.
Pragati
