Gantt task - editing by task info dialog only
Posted by: jaime.florez on 20 June 2019, 4:56 am EST
    Posted 20 June 2019, 4:56 am EST
    I need modify the task only with the task info dialog. The event is the same that modifying the task dragging with the mouse.
    How can i receive the dialog result?
  • Posted 21 June 2019, 2:13 am EST
    The sequence of events (when editing using TaskInfo dialog) is “ShowDialog” and then “BeforeEditTask”. You can use this information to Cancel the editing event if the editing was not performed through TaskInfo dialog.
    Please refer to the attached sample to see how you can do it.
    TaskInfoDialog_Editing.zip
    Jitender
