Help with comparing two C1TrueDBGrids and filtering based on selected field(s)
Posted by: Victor.m.charles.civ on 10 February 2020, 5:11 pm EST
    Posted 10 February 2020, 5:11 pm EST
    How do I compare Grid1 and Grid2 and display all records in Grid1 with identical data in Grid2 based on selected data fields?
    For example If Grid1 contains 3 records with same data in selected (FirstName, LastName, Zipcode) in Grid2, I would like to only display those records in Grid1 or if necessary display them in Grid3 if easier than using Grid1.
    Victor
  • Posted 11 February 2020, 12:28 am EST
    Hi Victor,
    There is no direct method to achieve this scenario but you can iterate among cells and get it done.
    We have attached a sample implementing the same, please have a look.
    If you have any other issue regarding this then please modify the sample accordingly.
    Prabhat
    TDBIdenticalRecords.zip
  • Posted 12 February 2020, 12:58 am EST
    How do I resolve the error below received when attempting to run the program?
    Severity Code Description Project File Line Suppression State
    Error Couldn’t process file Form1.resx due to its being in the Internet or Restricted zone or having the mark of the web on the file. Remove the mark of the web if you want to process these files. TDBIdenticalRecords
    Victor
  • Posted 12 February 2020, 1:26 am EST
    I was able to view the code, can you please explain what the code is doing.
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Dim dt As DataTable = New DataTable()
        Dim connectionString As String = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments), "ComponentOne Samples\Common\C1NWind.mdb") & ";"
        Dim conn As OleDbConnection = New OleDbConnection(connectionString)
        Dim adapter As OleDbDataAdapter = New OleDbDataAdapter("Select * from Data", conn)
        adapter.Fill(dt)
        C1TrueDBGrid1.DataSource = dt
        Dim dt1 As DataTable = New DataTable()
        adapter = New OleDbDataAdapter("Select * from Data where Qt=1", conn)
        adapter.Fill(dt1)
        C1TrueDBGrid2.DataSource = dt1
        For i As Integer = 0 To C1TrueDBGrid1.Splits(0).Rows.Count - 1
            Dim b As Boolean = False
            For j As Integer = 0 To C1TrueDBGrid2.Splits(0).Rows.Count - 1
                If C1TrueDBGrid1.Columns("Id").CellText(i).ToString = C1TrueDBGrid2.Columns("Id").CellText(j).ToString Then
                    b = True
                    Exit For
                End If
            Next
            Dim c As Boolean = False
                If C1TrueDBGrid1.Columns("Company").CellText(i).ToString = C1TrueDBGrid2.Columns("Id").CellText(j).ToString Then
                    c = True
                    Exit For
                End If
            Next
            Dim d As Boolean = False
                If C1TrueDBGrid1.Co
    I would like to select the fields to be compared by selecting the code below, instead of hard coding the fields. How do I implement it with your code?
        If ComboBox2.SelectedIndex = 0 Then
            yx = ""
            For Each Srow In Me.DBGrid1.SelectedRows
                If vc1 > 0 Then
                    yx = yx & "," & "'" & Me.DBGrid1.Columns(0).CellText(Srow) & "'"
                Else
                    yx = "'" & Me.DBGrid1.Columns(0).CellText(Srow) & "'"
                End If
                vc1 = vc1 + 1
                If yx.StartsWith(",") Then
                    yx = yx.Substring(1, yx.Length - 1)
                End If
                ' yx.TrimStart(",")
            Next
            apply = True
            C1AOP5.Refresh()
            C1AOP5.FetchRowStyles = True
            TextBox9.Visible = True
            Panel1.Visible = True
                   If ccc = 1 Then
                ccc = 0
            End If
        End If
    Victor
  • Posted 12 February 2020, 9:24 am EST
    Hello again,
    Unfortunately still can nit run the application. I’m assuming Grid1 is looking for identical data shared by same Id and company columns. I’m assuming the ID column can be any other columns because the data in the auto generated ID column will never match both tables.
    If possible can you please send me the code (VB.NET) to just copy and paste in my project, having difficulties opening applications received.
    Victor
  • Posted 13 February 2020, 6:57 am EST
    Hi Victor,
    The sample that I shared is bind to the Data table of the C1NWind database which is shipped along with the control. Please make sure the database file is available in your sample at location: …\Documents\ComponentOne Samples\Common
    If you still can not run the application then can you please share a GIF file showing the error message which you are getting at your end.
    Yes, you are right. As I have also taken Company and Cost column for the comparison.
    And we didn’t get what your code is actually doing so can you please modify the attached sample or share your stripped-down sample replicating the use-case.
  • Posted 13 February 2020, 7:51 am EST
    Hello Prabhat,
    The code below is creating a string of the columns I want to compare (e.g. ‘ID’, ‘Customer’, ‘cost’)
    How do I modify your code to include the string instead of hard coding the columns?
    Code:
    yx = “”
    If vc1 > 0 Then
    yx = yx & “,” & “'” & Me.DBGrid1.Columns(0).CellText(Srow) & “'”
    Else
    yx = “'” & Me.DBGrid1.Columns(0).CellText(Srow) & “'”
    End If
    vc1 = vc1 + 1
    If yx.StartsWith(“,”) Then
    Victor
  • Posted 14 February 2020, 6:38 am EST
    Hi Victor,
    Sorry, but your code has numbers of unknows like yx ,vc1… so it is not possible to use this code.
    But as per our understanding, you want to select the columns at runtime through Combobox which was hardcoded in my last attached sample so we have updated the sample as per this understanding. Please have a look.
    >>Severity Code Description Project File Line Suppression State Error Couldn’t process file Form1.resx due to its being in the Internet or Restricted zone or having the mark of the web on the file.
    If you downloaded the file from the internet, either separately or inside a .zip file or similar, it may have been “locked” because it is flagged as coming from the internet zone. Many programs will use this as a sign that the content should not be trusted.
    The simplest solution is to right-click the file in Windows Explorer, select Properties, and along the bottom of this dialog, you should have an “Unblock” option. Remember to click OK to accept the change.
    Prabhat Sharma
    TDBIdenticalRecords_Modifed.zip
  • Posted 14 February 2020, 5:37 pm EST
    Hello Prabhat,
    I am currently away from work until 26 Feb, will get back to you by 28 Feb.
    Victor
  • Posted 17 February 2020, 8:26 pm EST
    Meanwhile until back In the office on 26 Feb, can you please send me the code without the application.
    Victor
  • Posted 17 February 2020, 8:27 pm EST
    Victor
  • Posted 18 February 2020, 5:20 am EST
    Hi Victor,
    You can look at the Form1.vb file in the last attached for the code which I used to select the Columns from the ComboBoxes at runtime and showing the result on a button click.
    Prabhat Sharma
  • Posted 18 February 2020, 9:39 am EST
    Hello Prabhat,
    I don’t have access to my laptop, was hoping you can post the code for me to review while away from my office.
    Victor
  • Posted 19 February 2020, 1:18 am EST
    Hi Victor,
    Here the code is given below:
    Imports System.Data.OleDb
    Public Class Form1
            adapter.Fill(dt)
            adapter.Fill(dt1)
            ComboBox1.DropDownStyle = ComboBoxStyle.DropDownList
            ComboBox2.DropDownStyle = ComboBoxStyle.DropDownList
            ComboBox3.DropDownStyle = ComboBoxStyle.DropDownList
            For i As Integer = 0 To C1TrueDBGrid2.Columns.Count - 1
                ComboBox1.Items.Add(C1TrueDBGrid2.Columns(i).Caption)
                ComboBox2.Items.Add(C1TrueDBGrid2.Columns(i).Caption)
                ComboBox3.Items.Add(C1TrueDBGrid2.Columns(i).Caption)
            Next
            ComboBox1.SelectedIndex = 0
            ComboBox3.SelectedIndex = 0
        End Sub
        Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
                C1TrueDBGrid1.Splits(0).Rows(i).Visible = True
            Next
                    If ComboBox1.SelectedItem IsNot Nothing Then
                        If C1TrueDBGrid1.Columns(ComboBox1.SelectedItem).CellText(i).ToString = C1TrueDBGrid2.Columns(ComboBox1.SelectedItem).CellText(j).ToString Then
                            b = True
                            Exit For
                        End If
                    End If
                Next
                    If ComboBox2.SelectedItem IsNot Nothing Then
                        If C1TrueDBGrid1.Columns(ComboBox2.SelectedItem).CellText(i).ToString = C1TrueDBGrid2.Columns(ComboBox2.SelectedItem).CellText(j).ToString Then
                            c = True
                            Exit For
                        End If
                    End If
                Next
                    If ComboBox3.SelectedItem IsNot Nothing Then
                        If C1TrueDBGrid1.Columns(ComboBox3.SelectedItem).CellText(i).ToString = C1TrueDBGrid2.Columns(ComboBox3.SelectedItem).CellText(j).ToString Then
                            d = True
                            Exit For
                        End If
                    End If
                Next
                If Not d OrElse Not c OrElse Not b Then
                    C1TrueDBGrid1.Splits(0).Rows(i).Visible = False
                End If
            Next
        End Sub
    End Class
  • Posted 19 February 2020, 5:06 am EST
    Hello Prabhat,
    Thank you very much.
    Victor
  • Posted 19 February 2020, 5:41 am EST
    Hello Prabhat,
    Is is possible to use the values of yx in your code? I’m selecting the fields names from a DBGrid which gives me for example yx= ‘fieldname1’, ‘fieldname2’, ‘fieldname3’.
    If possible I would like to plug in the values of yx in your initial code to compare the selected fields data in both Grids instead of using aCombobox for each field name, if I understand your code correctly.
    Victor
  • Posted 19 February 2020, 6:08 am EST
    Hello again,
    If can only be achieved using Comboboxes, is it possible to create Comboboxes by code and pass values in yx to those Comboboxes while they are invisible? For example if yx contains 3 field names, 3 Comboboxes would be created to accept the 3 field names.
    Or is possible to only use one combobox to select multiple field names and modify the code?
    Victor
  • Posted 20 February 2020, 9:07 am EST
    Hi Victor,
    We are preparing the sample as per your need and will provide you shortly.
    Prabhat
  • Posted 20 February 2020, 12:49 pm EST
    Hello Prahabat,
    Can you please send me the code with comments, will run the test project when back to work next Wednesday.
    Victor
  • Posted 24 February 2020, 8:43 am EST
    Hi Victor,
    We have used C1MultiSelect control which can select multiple values from the combolist and show the desired result.
    Public Class Form1
            adapter.Fill(dt)
            adapter.Fill(dt1)
                C1MultiSelect1.Items.Add(C1TrueDBGrid2.Columns(i).Caption)
            Next
            C1MultiSelect1.TagWrap = True
        End Sub
            'Set the all rows to visible initially
            Next
            Dim b As Boolean() = New Boolean(C1MultiSelect1.SelectedItems.Count - 1) {}
            'If any column is selected by C1MultiSelect
            If C1MultiSelect1.SelectedItems.Count > 0 Then
                'Iterate for all rows of main TDB
                    'Iterate for each column selected by C1MultiSelect
                    For k As Integer = 0 To C1MultiSelect1.SelectedItems.Count - 1
                        b(k) = False
                        'Iterate with all rows of comparing TDB
                            If C1MultiSelect1.SelectedItems(k).Value IsNot Nothing Then
                                If C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(j).ToString Then
                                    b(k) = True
                                    Exit For
                                End If
                            End If
                        Next
                    Next
                    Dim temp = False
                    For l As Integer = 0 To b.Count - 1
                        If b(l) = False Then
                            temp = True
                            Exit For
                        End If
                    Next
                    If temp Then
                    End If
                Next
            End If
        End Sub
    End Class
    Prabhat
  • Posted 25 February 2020, 1:37 pm EST
    I modified the code in my project to load the Grids with xml files, but when I click on the button1 for filter Grid1 based on fields selected, it does not work, after running some test, notice MsgBox(“nnn”) does nor execute even though both fields gave identical data in both Grids. can you please help this issue.
    Public Class Form1
    Public fsLinkCHPT As System.IO.FileStream
    Public dtsetLinkCHPT As New DataSet
    Public fsLinkCTRY As System.IO.FileStream
    Public dtsetLinkCTRY As New DataSet
    Public vc11 As Integer = 0
        fsLinkCHPT = New System.IO.FileStream(Application.StartupPath + "\AOP5A.xml", IO.FileMode.Open)
        dtsetLinkCHPT.Clear()
        dtsetLinkCHPT.ReadXml(fsLinkCHPT)
        fsLinkCHPT.Close()
        Me.C1TrueDBGrid1.DataSource = dtsetLinkCHPT.Tables(0)
        'LOAD COUNTRIES
        fsLinkCTRY = New System.IO.FileStream(Application.StartupPath + "\AOP5B.xml", IO.FileMode.Open)
        dtsetLinkCTRY.Clear()
        dtsetLinkCTRY.ReadXml(fsLinkCTRY)
        fsLinkCTRY.Close()
        Me.C1TrueDBGrid2.DataSource = dtsetLinkCTRY.Tables(0)
        Next
        Next
    End Sub
        Next
                    b(k) = False
                                b(k) = True
                                Exit For
                            End If
                        End If
                    Next
                Next
                MsgBox("lll")
                Dim temp = False
                        temp = True
                        Exit For
                    End If
                Next
                MsgBox("mm")
                If temp Then
                    MsgBox("nnn") ' ************* Does not execute
                End If
            Next
        End If
    End Sub
  • Posted 25 February 2020, 1:38 pm EST
    Public Class Form1
        fsLinkCHPT.Close()
        'LOAD COUNTRIES
        fsLinkCTRY.Close()
        Next
        Next
    End Sub
        Next
                    b(k) = False
                                b(k) = True
                                Exit For
                            End If
                        End If
                    Next
                Next
                MsgBox("lll")
                Dim temp = False
                        temp = True
                        Exit For
                    End If
                Next
                MsgBox("mm")
                If temp Then
                End If
            Next
        End If
    End Sub
  • Posted 25 February 2020, 1:39 pm EST
    Public Class Form1
        fsLinkCHPT.Close()
        'LOAD COUNTRIES
        fsLinkCTRY.Close()
        Next
        Next
    End Sub
        Next
                    b(k) = False
                                b(k) = True
                                Exit For
                            End If
                        End If
                    Next
                Next
                MsgBox("lll")
                Dim temp = False
                        temp = True
                        Exit For
                    End If
                Next
                MsgBox("mm")
                If temp Then
                End If
            Next
        End If
    End Sub
  • Posted 25 February 2020, 1:40 pm EST
    Sorry for the multiple post, didn’t notice it was posted on a page 2.
  • Posted 25 February 2020, 3:32 pm EST
    Hello again,
    It seems to be working, it was not working because I was using the same table in both Grids.
    Is there a way to modify the code to filter Grid1 using the AND or OR approach with multiple fields, I believe the solution you provided me is using the AND approach. For example using the “AND” approach the rows in Grid1 must have identical data as of Grid2. Using the “OR” approach the rows in Grid1 with be displayed if identical data is eith fields selected.
    Victor
    Victor
  • Posted 25 February 2020, 6:45 pm EST
    I noticed an inconsistency in the solution, You 'll notice this issue when you select the FIF field, second row with NSN ending with 9991 should not be displayed in Grid1 because the data in both Grids don’t match. How do I fix this issue?
    It works when I select the NSN field using the default [OR] operator. Also hw do I modify the code if I select the [AND] operator, where the data must be the same in all selected fields for each row in both Grids?
    VictorGRIDTESTING022520.zip
  • Posted 26 February 2020, 4:21 am EST
    Hi Victor,
    As we are filtering the first TDB based on the similar values in second TDB so when filtering based on the FIF column, all the records of the first TDB in FIF column if matches with any record of the FIF column of second TDB then that row will be visible in second TDB.
    We have modified your attached sample with OR and AND both the filters based on the value selected by Radio button, please have a look.
    If both the grids have the same number of records and you want to compare data row by row in both the grids then please let us know.
    Prabhat Sharma,
  • Posted 26 February 2020, 6:38 am EST
    Hello Prabhat,
    Please take a look at the image, I change NA/99 to NB99 but it should not make a difference, When I filter by FIF, the second row in Grid1 should not be displayed because the value in Grid2 in NB99 and the value in Grid1 is N/A in the FIF column.
    I will run more test in the AND option and get back to you. Basically if I select the AND operator, both grids must have identical data in rows for all the selected fields.
    For example if I filter by NSN and FIF both grids must have rows with same data for both FIF and NSN.
    Thank you,
    Victor
    FIF_Image.zip
  • Posted 26 February 2020, 7:39 am EST
    As per our understanding, you want to compare data row by row in both the grids so we have updated the sample accordingly, please have a look and let us know if you find this useful.
    GRIDTESTING022520_Modified.zip
  • Posted 26 February 2020, 12:03 pm EST
    Hi Prabhat,
    It seems to be working GREAT!,
    THANK YOU
    Victor
  • Posted 26 February 2020, 12:22 pm EST
    Hello Prabhat,
    One more question on this issue.How do I display the result in another Grid? For example C1TrueDBGrid3, I think it would be user friendlier than having to reload Grid1 for each search.
    Victor
  • Posted 27 February 2020, 2:37 am EST
    Hello Victor,
    I am glad to know that the last sample worked for you as you desired.
    One more question on this issue. How do I display the result in another Grid? For example C1TrueDBGrid3
    I have updated the last sample and showed the filter result in another grid i.e. TrueDBGrid3, please have a look.
    GRIDTESTING022520_Mod_2.zip
  • Posted 27 February 2020, 9:53 am EST
    Hello Prabhat,
    Thanks for the solution will test it and get back to you. Is it possible to show matching records from both Grid1 and Grid2 in Grid3.
    Victor
  • Posted 27 February 2020, 10:11 am EST
    Hello Prabhat,
    The solution to display the results in Grid3 id working great.
    Victor
  • Posted 28 February 2020, 2:45 pm EST
    Hello Prabhat,
    Victor
  • Posted 29 February 2020, 10:25 am EST
    Hello Prabhat,
    I tried to modify your code in the bottom part of code below to do the same for Grid2 but receiving error message: “Can not find column 0” on line: C1TrueDBGrid2.Splits(0).DisplayColumns(row).DataColumn.CellText(i)
    In addition of trying to display results for both Grids in Grid3.
    I would also like to displays their results in separate Grids (Grid3 for Grid1 and Grid4 for Grid2)
    Code:
    ’ C1TrueDBGrid1.Splits(0).Rows(i).Visible = True
    Next
        C1TrueDBGrid3.Rows.Clear()
        C1TrueDBGrid4.Rows.Clear()
        Dim c As Boolean() = New Boolean(C1MultiSelect1.SelectedItems.Count - 1) {}
                    b(k) = False
                    If C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i).ToString Then
                        b(k) = True
                    End If
                Next
                'And Filter
                If RadioButton2.Checked Then
                    'And Filter
                    Dim temp = False
                            temp = True
                            Exit For
                        End If
                    Next
                    If Not temp Then
                        '  C1TrueDBGrid1.Splits(0).Rows(i).Visible = False
                        Dim dr As DataRow = Me.C1TrueDBGrid3.NewRow
                        For row As Integer = 0 To C1TrueDBGrid1.Splits(0).DisplayColumns.Count - 1
                            dr(row) = C1TrueDBGrid1.Splits(0).DisplayColumns(row).DataColumn.CellText(i)
                        Next
                        C1TrueDBGrid3.Rows.Add(dr)
                    End If
                    If Not temp Then
                        Dim dr As DataRow = Me.C1TrueDBGrid4.NewRow
                        Next
                        C1TrueDBGrid4.Rows.Add(dr)
                    End If
                End If
                'Or Filter
                If RadioButton1.Checked Then
                    Dim temp = True
                        If b(l) = True Then
                            temp = False
                            Exit For
                        End If
                    Next
                    '  MsgBox("mmmmmmmm")
                    If Not temp Then
                        '  MsgBox("nnn")
                        Next
                    End If
                End If
            Next
        End If
        ' DO SAME RESULTS FOR GRID2
                     For i As Integer = 0 To C1TrueDBGrid2.Splits(0).Rows.Count - 1
                    c(k) = False
                    If C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i).ToString Then
                        c(k) = True
                    End If
                         Next
                         'And Filter
                             'And Filter
                             Dim temp = False
                    For l As Integer = 0 To c.Count - 1
                        If c(l) = False Then
                            temp = True
                            Exit For
                        End If
                    Next
                    If Not temp Then
                                 '  C1TrueDBGrid2.Splits(0).Rows(i).Visible = False
                                 For row As Integer = 0 To C1TrueDBGrid2.Splits(0).DisplayColumns.Count - 1
                                     dr(row) = C1TrueDBGrid2.Splits(0).DisplayColumns(row).DataColumn.CellText(i)
                                 Next
                             End If
                             If Not temp Then
                                 Next
                             End If
                         End If
                         'Or Filter
                             Dim temp = True
                                 If b(l) = True Then
                                     temp = False
                                     Exit For
                                 End If
                             Next
                             If Not temp Then
                                 '  MsgBox("nnn")
                                 Next
                             End If
                         End If
                     Next
                 End If
             End Sub
    Victor
  • Posted 29 February 2020, 4:35 pm EST
    I was able to get the results from Grid2 in Grid4 using the code below, my only issue now to be results from both Grids 1 & 2 in Grid3.
            '  C1TrueDBGrid1.Splits(0).Rows(i).Visible = True
        Next
                    b(k) = False
                    If C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i).ToString Then
                        b(k) = True
                    End If
                Next
                'And Filter
                    'And Filter
                    Dim temp = False
                            temp = True
                            Exit For
                        End If
                    Next
                    If Not temp Then
                        Next
                    End If
                    If Not temp Then
                        Next
                    End If
                End If
                'Or Filter
                    Dim temp = True
                        If b(l) = True Then
                            temp = False
                            Exit For
                        End If
                    Next
                    If Not temp Then
                        '  MsgBox("nnn")
                        Next
                    End If
                End If
            Next
        End If
        ' Display data og GRID2
            '  C1TrueDBgrid2.Splits(0).Rows(i).Visible = True
        Next
                    b(k) = False
                        b(k) = True
                    End If
                Next
                'And Filter
                    'And Filter
                    Dim temp = False
                            temp = True
                            Exit For
                        End If
                    Next
                    If Not temp Then
                        '  C1TrueDBgrid2.Splits(0).Rows(i).Visible = False
                        Next
                    End If
                End If
                'Or Filter
                    Dim temp = True
                        If b(l) = True Then
                            temp = False
                            Exit For
                        End If
                    Next
                    If Not temp Then
                        '  MsgBox("nnn")
                        Next
                    End If
                End If
            Next
        End If
    End Sub
    Victor
  • Posted 2 March 2020, 5:40 am EST
    Hi Victor,
    Please modify the code as per your need in the last attached sample and share it back.
    It will be very helpful if you could send the screenshot of the output that you are getting at your end and modified screenshot with the requirements that you want to achieve.
  • Posted 2 March 2020, 11:18 am EST
    Hello Prabhat.
    Enclosed is the latest test project. I would like to load Grid5 with data from Grid1 output(Grid3) and Grid 2 output (Grid4) sorted by NSN SCOUNTRY and COUNTRY Columns
    Victor
  • Posted 3 March 2020, 5:30 am EST
    TrueDBGrid does not have programmatic sorting and we would need to modify the DataSource for applying for a sort order.So we need to take the data identical in both the grids (grid3 and grid4) into a DataTable and bind that DataTable to the Grid5 to achieve the desired scenario.
    GRIDTESTING022520_Grid5_MOD.zip
  • Posted 3 March 2020, 9:19 pm EST
    Hello Prabhat,
    It works. Thank you.
    Is it possible to sort Grid5 by fields selected in the Multiselect control?
    Victor
  • Posted 4 March 2020, 12:12 am EST
    Hello Victor,
    Just use the code snippet given below to set the Sort property of the DataView as per your MultiSelect selected values.
    Dim str As String = C1MultiSelect1.SelectedItems(0).Value.ToString + " ASC"
    For item As Integer = 1 To C1MultiSelect1.SelectedItems.Count - 1
     str = str + "," + C1MultiSelect1.SelectedItems(item).Value.ToString + " ASC"
    Next
    Dim DataView As DataView = dt.AsDataView()
    DataView.Sort = str
    C1TrueDBGrid5.DataSource = DataView
  • Posted 6 March 2020, 2:39 pm EST
    Hello Prabhat,
    It works. Thanks.
    How do I highlight column headers of selected column(s).
    Victor
  • Posted 9 March 2020, 2:45 am EST
    It is not possible to highlight the headers selected column but you can highlight the column which contains column selector by using code snippet given below:
     c1TrueDBGrid1.ColumnSelectorStyle.BackColor = Color.Red
    Note: As this is a different case so you are requested to create a new case for this and close this case if the initial requirement of this case is met.
  • Posted 14 March 2020, 12:46 am EST
    OK. Thanks
  • Posted 27 May 2020, 10:08 pm EST
    Hello Prabhat,
    Is it possible to reopen this case or should I open a new case? I noticed when comparing Grid1 and Grid2 for identical data in selected field, not all the matching records in Grid2 are displayed in Grid4. For example if you select the SN field, you’ll notice Grid4 only incudes the exact number of records in Grid1, even though Grid2 contains additional records where SN = 10411. How do I modify the code to fix this issue?
  • Posted 28 May 2020, 5:19 am EST
    Hello Victor,
    As this thread has been taken too long so you are requested to create a new case if you have any further queries.
    To achieve the desired result as, please update the code of Button1 click event as given below:
            Next
                        b(k) = False
                            b(k) = True
                        End If
                    Next
                    'And Filter
                        Dim temp = False
                                temp = True
                                Exit For
                            End If
                        Next
                        If Not temp Then
                            Next
                        End If
                        If Not temp Then
                            Next
                        End If
                    End If
                    'Or Filter
                        Dim temp = True
                            If b(l) = True Then
                                temp = False
                                Exit For
                            End If
                        Next
                        If Not temp Then
                            Next
                        End If
                    End If
                Next
            End If
            ' Display data in GRID2
            Next
                        b(k) = False
                            If C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(j).ToString Then
                                b(k) = True
                                Exit For
                            End If
                        Next
                    Next
                        'And Filter
                        'And Filter
                        Dim temp = False
                                temp = True
                                Exit For
                            End If
                        Next
                        If Not temp Then
                            Next
                        End If
                    End If
                    'Or Filter
                        Dim temp = True
                            If b(l) = True Then
                                temp = False
                                Exit For
                            End If
                        Next
                        If Not temp Then
                            Next
                        End If
                    End If
                Next
            End If
        End Sub
