Help with displaying Grids record count
Posted by: victor_charles on 26 April 2020, 12:56 pm EST
    Posted 26 April 2020, 12:56 pm EST
    How do I modify the code below to view the correct record count of the Grid, the code below with rowcount does not work because the number does not change when the record count changes.
    Private Sub Button12_Click(sender As System.Object, e As System.EventArgs) Handles Button12.Click
    Dim FilteredDTA As DataTable
    If RadioButton1.Checked Then
    Dim xyz As String = “”
    If C1TrueDBGrid2.SelectedRows.Count = 0 Then
    For row1 = 0 To C1TrueDBGrid1.SelectedRows.Count - 1
    xyz = xyz + “[” + C1Screen1.Columns(“SN”).Caption + “] LIKE’” + C1TrueDBGrid1.Columns(“CHPT”).CellText(C1TrueDBGrid1.SelectedRows(row1)) + “%’ OR”
    Next
    ElseIf C1TrueDBGrid1.SelectedRows.Count = 0 Then
    For row = 0 To C1TrueDBGrid2.SelectedRows.Count - 1
    Dim str As String
    str = C1TrueDBGrid2.Columns(“COUNTRY”).CellText(C1TrueDBGrid2.SelectedRows(row))
    xyz = xyz + “[” + C1Screen1.Columns(“COUNTRY”).Caption + “]='” + str + “’ OR”
    Next
    Else
    Dim str As String
    xyz = xyz + “[” + C1Screen1.Columns(“COUNTRY”).Caption + “]='” + str + “’ AND [” + C1Screen1.Columns(“SN”).Caption + “] LIKE’” + C1TrueDBGrid1.Columns(“CHPT”).CellText(C1TrueDBGrid1.SelectedRows(row1)) + “%’ OR”
    Next
    Next
    End If
    xyz = xyz.Remove(xyz.Length - 3, 3)
            Console.WriteLine(xyz)
            fsLinkTest = New System.IO.FileStream(Application.StartupPath + "\AOP40.xml", IO.FileMode.Open)
            dtsetLinkTest.Clear()
            dtsetLinkTest.ReadXml(fsLinkTest)
            fsLinkTest.Close()
            FilteredDTA = dtsetLinkTest.Tables(0)
            Dim view As DataView
            view = New DataView(FilteredDTA)
            view.RowFilter = xyz
            C1Screen1.Refresh()
            C1Screen1.DataSource = view
        End If
        If RadioButton2.Checked Then
            Dim xyz As String = ""
                    Dim str As String
                    str = C1TrueDBGrid2.Columns("COUNTRY").CellText(C1TrueDBGrid2.SelectedRows(row))
                    xyz = xyz + "[" + C1Screen1.Columns("COUNTRY").Caption + "]='" + str + "' OR"
                Next
            Else
                        Dim str As String
                        xyz = xyz + "[" + C1Screen1.Columns("COUNTRY").Caption + "]='" + str + "' AND [" + C1Screen1.Columns("SN").Caption + "] LIKE'" + C1TrueDBGrid1.Columns("CHPT").CellText(C1TrueDBGrid1.SelectedRows(row1)) + "%' OR"
                    Next
                Next
            End If
            fsLinkTest.Close()
            C1Screen1.Refresh()
            Dim visible = True
            For row = 0 To C1Screen1.Splits(0).Rows.Count - 1
                visible = False
                For row1 = 0 To C1Screen1.Splits(0).Rows.Count - 1
                    If row <> row1 Then
                        If C1Screen1.Columns("SN").CellValue(row) = C1Screen1.Columns("SN").CellValue(row1) AndAlso C1Screen1.Columns("COUNTRY").CellValue(row) <> C1Screen1.Columns("COUNTRY").CellValue(row1) Then
                            visible = True
                            Exit For
                        End If
                    End If
                Next
                C1Screen1.Splits(0).Rows(row).Visible = visible
            Next
        End If
        'View Grid
        If C1Screen1.RowCount <> 0 Then
              C1Screen1.Visible = True
            TextBox1.Text = C1Screen1.RowCount '*****Does not work
        End If
    End Sub
  • Posted 27 April 2020, 5:12 am EST
    Hi Victor,
    Your case has been replied on the given link, please continue the thread there only:
    https://www.grapecity.com/forums/winforms-edition/how-to-view-grids-record-c
