Posted 30 May 2020, 1:07 pm EST
How do I modify the code in Button2 to display search results in Grid2 in 3 separate Grids? For example I would like to display the search results in the following format:
Columns, 1,2,3 in Grid2 Part A
Columns, 1,4,5 in Grid2 Part B
Columns, 1,6,7 in Grid2 Part C
Code:
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click 'Set the all rows to visible initially For i As Integer = 0 To C1TrueDBGrid1.Splits(0).Rows.Count - 1 Next C1TrueDBGrid3.Rows.Clear() Dim b As Boolean() = New Boolean(C1MultiSelect1.SelectedItems.Count - 1) {} C1TrueDBGrid4.Rows.Clear() Dim c As Boolean() = New Boolean(C1MultiSelect1.SelectedItems.Count - 1) {} 'If any column is selected by C1MultiSelect If C1MultiSelect1.SelectedItems.Count > 0 Then 'Iterate for all rows of main TDB For i As Integer = 0 To C1TrueDBGrid1.Splits(0).Rows.Count - 1 'Iterate for each column selected by C1MultiSelect For k As Integer = 0 To C1MultiSelect1.SelectedItems.Count - 1 b(k) = False If C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i).ToString Then b(k) = True End If Next 'And Filter If RadioButton2.Checked Then Dim temp = False For l As Integer = 0 To b.Count - 1 If b(l) = False Then temp = True Exit For End If Next If Not temp Then Dim dr As DataRow = Me.C1TrueDBGrid3.NewRow For row As Integer = 0 To C1TrueDBGrid1.Splits(0).DisplayColumns.Count - 1 dr(row) = C1TrueDBGrid1.Splits(0).DisplayColumns(row).DataColumn.CellText(i) Next C1TrueDBGrid3.Rows.Add(dr) End If If Not temp Then Dim dr As DataRow = Me.C1TrueDBGrid4.NewRow For row As Integer = 0 To C1TrueDBGrid1.Splits(0).DisplayColumns.Count - 1 dr(row) = C1TrueDBGrid1.Splits(0).DisplayColumns(row).DataColumn.CellText(i) Next C1TrueDBGrid4.Rows.Add(dr) End If End If 'Or Filter If RadioButton1.Checked Then Dim temp = True For l As Integer = 0 To b.Count - 1 If b(l) = True Then temp = False Exit For End If Next If Not temp Then Dim dr As DataRow = Me.C1TrueDBGrid3.NewRow For row As Integer = 0 To C1TrueDBGrid1.Splits(0).DisplayColumns.Count - 1 dr(row) = C1TrueDBGrid1.Splits(0).DisplayColumns(row).DataColumn.CellText(i) Next C1TrueDBGrid3.Rows.Add(dr) End If End If Next End If ' Display data in GRID2 'Set the all rows to visible initially For i As Integer = 0 To C1TrueDBGrid2.Splits(0).Rows.Count - 1 Next C1TrueDBGrid4.Rows.Clear() 'If any column is selected by C1MultiSelect If C1MultiSelect1.SelectedItems.Count > 0 Then 'Iterate for all rows of main TDB For i As Integer = 0 To C1TrueDBGrid2.Splits(0).Rows.Count - 1 'Iterate for each column selected by C1MultiSelect For k As Integer = 0 To C1MultiSelect1.SelectedItems.Count - 1 b(k) = False For j As Integer = 0 To C1TrueDBGrid2.Splits(0).Rows.Count - 1 If C1TrueDBGrid2.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(i) = C1TrueDBGrid1.Columns(C1MultiSelect1.SelectedItems(k).Value.ToString).CellText(j).ToString Then b(k) = True Exit For End If Next Next 'And Filter If RadioButton2.Checked Then 'And Filter Dim temp = False For l As Integer = 0 To b.Count - 1 If b(l) = False Then temp = True Exit For End If Next If Not temp Then Dim dr As DataRow = Me.C1TrueDBGrid4.NewRow For row As Integer = 0 To C1TrueDBGrid2.Splits(0).DisplayColumns.Count - 1 dr(row) = C1TrueDBGrid2.Splits(0).DisplayColumns(row).DataColumn.CellText(i) Next C1TrueDBGrid4.Rows.Add(dr) End If End If 'Or Filter If RadioButton1.Checked Then Dim temp = True For l As Integer = 0 To b.Count - 1 If b(l) = True Then temp = False Exit For End If Next If Not temp Then Dim dr As DataRow = Me.C1TrueDBGrid4.NewRow For row As Integer = 0 To C1TrueDBGrid2.Splits(0).DisplayColumns.Count - 1 dr(row) = C1TrueDBGrid2.Splits(0).DisplayColumns(row).DataColumn.CellText(i) Next C1TrueDBGrid4.Rows.Add(dr) End If End If Next End If End Sub
Victor
How do I modify to GRIDTESTING022520.zip
